WILL MY 305 MANIFOLDS FIT MY 98 VORTEC HEADS?
Car: 1991 Trans Am GTA
Engine: 350 tpi
I was just curious will my 87 iroc 305 manifolds fit my 98 vortec heads i got..cause nobody wants to put my y pipe on since my motor is not in and figured if the manifolds fit ill just put them...only problem is the dip stick does not fit cause on this motor its on the driver side any help would be great thanks.
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
Re: WILL MY 305 MANIFOLDS FIT MY 98 VORTEC HEADS?
nope...mine dont fit my vortecs im in process of trying to figure out which headers im getting right now to get car back on road again
Engine: 350 tpi
really dam man ha ha that sucks...good thing i didnt sell the set of headers i got awhile back...im going to have to run open headers since nobody wants to do my y pipe for me.
Car: 1983 Pontiac Firebird
Engine: 400HP 350
I dont understand why manifolds wouldnt fit with vortec heads... I have 350TPI manfoldwith a stock 3" y-pipe and if I put those on my vortec heads they'd fit no issues... I'm runing edelbrock headers on my car only because its emmions exempt in CT.... Oh, and i'm selling those manifolds and y-pipe if anyones interested..lol
Engine: 350 tpi
lol awesome motor man!! and i have not tried it yet but i guess it defeats the purpose of putting vortecs if ur running the stock manifolds huh lol...also what color did u use on ur motor?
Engine: 400HP 350
Engine: 400HP 350
1990 Chevy 350 Block
One piece rear main seal
Stock Cast Crank (balanced)
LT1 Connecting rods
SpeedPro Hypereutectic Pistons w/Coated Skirts
10.6:1 compression
CompCams DUAL Energy™ Hydraulic Flat Tappet Camshaft
Details http://www.compcams.com/Cam_Specs/Ca...?csid=105&sb=2
906 casting Vortec Head clearance for .500lift
CompCams valve springs w/titanium retainers and locks
Weiand Stealth Intake
Proform roller tip rockers
Edelbrock 650 Thunder AVS
LT1 Connecting rods
10.6:1 compression
Engine: 350sbc
stock manifold bolt hole on cyclinder 8 is father back..and the vortecs use the closer bolt hole which the manifold does not have due to where it goes down at...its possible to find a stock manifold from another car that might fit but mine did not...but thats ok who wants to run stock manifolds with vortec heads anyhow...i was just ganna do it till i was able to afford the headers
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
