Exhaust wraps??? Good or bad?
Old Jun 25, 2010 | 12:20 AM
PT3BOOMER's Avatar
Car: 84 Z28 / 99 S-10 ZR2 4X4
Engine: STOCK CARB'D 305 WITH 350 HEADS
Axle/Gears: STOCK
I have a set of hedman 1 5/8" long tubes on my 84 z28 with 3in exhaust. I getting a lot of heat under the hood and I'm thinking about thermo wrapping the headers...what y'all think?
Old Jun 25, 2010 | 02:21 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Exhaust wraps??? Good or bad?
That'll void the warranty, just something to think about.
If that doesn't bother you, personally I'd rather have them wrapped than bare.
Old Jun 25, 2010 | 03:22 AM
PT3BOOMER's Avatar
Axle/Gears: STOCK
Warranty doesn't concern me unless my buddy still had the reciepts for'em.....but I heard they corrode faster with the wraps on
Old Jun 25, 2010 | 08:52 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
I have mine wrapped (shorties) and they work fine for me. I always enjoy when people think that wraps will completely disintegrate a set of headers in a year. Can they cause them to rust, yes, but so will driving around without wraps. Unless they are made from stainless or coated all headers will eventually corrode (but will still probably outlast the engine/car they were put in)
Old Jun 25, 2010 | 08:59 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
If mine are already years old, and already fully corroded and brown, there's no harm in wrapping them at this stage right? Or will it damage the header in some way?
Old Jul 6, 2010 | 02:30 PM
gordonjj's Avatar
Originally Posted by PT3BOOMER
Warranty doesn't concern me unless my buddy still had the reciepts for'em.....but I heard they corrode faster exhaust wraps on
Yes, they corrode faster and once you try it the warranty is not going to work, I doubt they'll replace it.
Old Jul 6, 2010 | 02:44 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Mine are wrapped Headman shorties and it did make a difference in under hood temp. Also my car is only driven on nice days, It's not a daily driver so the corrosion thing is not an issue for me.
Mark.
Old Jul 6, 2010 | 03:33 PM
Yeha i only drive my car in the sunshine (no rain, and definitely not snow or below freezing temps), so is there any risk to putting these on? Reducing underhood temps can only be good no?
Old Jul 6, 2010 | 04:39 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
I've only had mine wrapped for about 2 months so I can't tell ya long term but short term so far so good.
Mark.
Old Jul 6, 2010 | 04:48 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
From what I have been told, wrapping them causes the internal temperature to reach such a level that the steel begins to break down molecularly. That heat is normally radiated out...
Ceramic coating, done inside and out, actually protects the steel- I would go with that rather than wrapping.
Corrosion, what we would normally call rust, should not be an issue with wrapped headers- they won't retain moisture under normal circumstances, since it will just evaporate off due to the heat- it is that molecular breakdown that is the problem...
Old Jul 19, 2010 | 10:55 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
on my 87 I used it
I put it on my shorty headers and my y pipe all the way to were the cat used to be...
It lowered my under hood temp 150 degrees
In my oppinion its the best thing I have done to my car under hood wise I have about 200 $ in it all
Old Jul 20, 2010 | 01:11 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
A friend of mine has a 69 Cutlass Supreme and wrapped his headers....
Kept the primary tubes cool enough to touch them quickly.... You'll never do that with unwrapped headers!!!!
Obviously his under hood temps are way down...
As far as Voiding a warranty...
Headers are cheap!!!! Who cares if they get changed every 5 years?
Either way they're gonna get rusty.... and burn through eventually.
I went Ceramic coated.... (& I think they're still hot!!!) but for what it's worth I'm gonna wrap my Y-Pipe.)
Old Jul 20, 2010 | 09:15 AM
I know this may be a silly question but... Could they ever catch fire? Also, how far should you wrap them? All the way to the cat, or further?
Old Jul 20, 2010 | 09:35 AM
Twin_Turbo's Avatar
The wrap itself won't burn but it can act as a wick (oil leaking into the headers), that's why I always liberally spray my wrapped headers with silicone. Just the headers will do, not as far back as the cat con. To the collector is fine.
Old Jul 20, 2010 | 01:03 PM
What does spraying it with silicone do?
Old Jul 20, 2010 | 01:37 PM
Twin_Turbo's Avatar
Preventing it from becoming a wick. The silicone saturates the .wrap
Old Jul 20, 2010 | 04:06 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Axle/Gears: 410
All the way back to cat was prolly a little overkill but it helped me alot...
My temps was only down about 100 degree with headers and with y pipe wrapped it was down 150 degree under hood
Old Jul 20, 2010 | 04:12 PM
PT3BOOMER's Avatar
Axle/Gears: STOCK
So ceramic coat or wrap?
Old Jul 20, 2010 | 08:40 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
I've seen my ceramic coated headers glow red/pink during a "lean" break-in condition. So hot that they melted my Accel plug wires, then they caught on fire!!! I ordered new wires and boot protectors http://www.summitracing.com/parts/TAY-2566/
So even though ceramic coatings are used to keep temps down I would say that they don't compare to wraps!!!!
If ya got the $$$ do both....
That's my
Old Jul 22, 2010 | 03:28 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
no they don't. I had my shorties wrapped for something like 5 years and they looked like new when I unwrapped them to sell them. If you drive in salt in winter, all bets are off.
no risk, you'll like them I promise. I also noticed the plastic tubing my wires and stuff are in stopped baking and getting brittle. I think my wrapped shorties had lower under hood temps than my ceramic coated long tubes do, but I can't prove it.
Some people claim wrapping "mummifies" the headers and they can't breathe properly but I don't buy this. If you're wrapping a good quality header you'll be fine. If you're running junk headers, or if your exhaust is in a bind constantly pulling on the headers, then you're going to have problems with cracks and breakage regardless of wether or not it's wrapped.
Old Jul 22, 2010 | 03:30 PM
Twin_Turbo's Avatar
Yes, the wrap will have a much bigger effect on underhood temps than ceramic coated headers ever will.
Old Jul 23, 2010 | 06:43 PM
Guest
Guest
Posts: n/a
My father has a magnaflow system,Im going with the the pypes
Old Jul 23, 2010 | 11:33 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
What ?????????
How does that statement pertain to the Original Poster's question???
Old Jul 24, 2010 | 08:16 PM
Pocket's Avatar
Car: 91 Trans Am
Not even close. If that were true steel couldnt be welded for anything structural
Old Jul 24, 2010 | 09:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if that was the case, the heads would start to break down too, especially the aluminum ones
Old Jul 25, 2010 | 10:43 AM
Wow can't beleive i didnt think of that one lmao..
Old Jul 28, 2010 | 04:51 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I just got my headers ceramic coated. Think I'll wrap them and the i-pype as well.
Any brand wrap better than the other?
Old Jul 29, 2010 | 08:40 AM
definitely gonna get a set as well.. best brand for edelbrock shorty headers??
Old Jul 29, 2010 | 10:21 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
I don't think that any "ONE" brand is better than the other..... especially for a particular manufacturers header.... Take your pick! There's fiberglass, ceramic, carbon fiber...... whatever
1" wide would be good for headers, but I'm sure you could use 2"....
To figure it out how much length you need take your 1 5/8" primary tube size (for ease of the example lets say 1.75" X by pi=3.141593 = 5.49" circumference)
Measure the combined length of each primary tube and multiply by 5.5"
Remember you'll be overlapping each layer by about 1/2 so double the equation....
Don't forget the collectors!!!
Old Jul 29, 2010 | 01:37 PM
2" wide wrap gives you better bang for your buck... Why?
Because you want to overlap each strip by 1/4".
A 1" wide wrap effectively becomes 3/4" wide, and 2" wide wrap effectively becomes 1 3/4" wide.
Might seem like a small difference, but it adds up. Just thought I'd throw that out there.
Old Jul 29, 2010 | 01:43 PM
Twin_Turbo's Avatar
A 2" wrap is much harder to get around tight bends like primaries. I have 2" wrap that i only use for downpipes. Get the 1" wrap.
Old Jul 2, 2015 | 07:41 AM
bluethumb's Avatar
I wrapped the exhaust pipes around the transmissions on a Navajo and a Bronco II years ago, both daily drivers and off road use. have not had any trouble with either.
Old Jul 2, 2015 | 10:29 AM
I actually just bought a kit of DEI wrap, going to get that done at some point this winter. 5 years after I originally posted in here, and still didn't do it yet lol. Shame on me haha
Old Jul 2, 2015 | 10:53 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Header wrap is just a band aid...find out what is causing the excess heat.
Might be timing or tune.
86IROC112
Apr 9, 2016 10:20 PM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
