removing cat?
Car: 1991 Formula
Engine: 350TBI
removing cat?
Would my SES light come on if i removed my car? i know it will give me bad emissions but will the light turn on?
Car: 87 GTA
Re: removing cat?
Possibly. And it would be tampering with Federal Emissions on a street car. If it is bad? Get a high flow cat, but don't take off a good cat.
Re: removing cat?
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: removing cat?
You are not going to get a SES light. It's not going to give you a lot of problems if you do. As stated above, it is illegal to do. It also will make your exhaust much "stronger" smelling.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: removing cat?
Correct. There aren't any rear 02 sensors on these cars to detect cat temperature, which is what would trip an code on a modern car. Ditto on the emissions. Modern cats do not rob power. Improper exhaust size does.
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: removing cat?
My cats are hollow. They look like cats, but are empty. I have no problems with performance, or or lights coming on, but I probably have a strong exhaust smell. I am going to get around to putting high flow cats on them. I grew up when catalytic converter wasn't even a word, so you probably know what my gut feeling is about the EPA.
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
Re: removing cat?
x2. You're better off leaving it in unless it's bad, then you may as well get a high flow... but if you have a sniffer test in your state it may not pass emissions.
Re: removing cat?
keep it green...keep it shiny
