will aftermarket headers for a 89 lo3 fit an lt1 or a 400 block
Old 07-25-2010, 09:52 AM
hasty88-and-89's Avatar
Car: 89RS-5.0/88IROC-Z-5.0/92-5.7 z28/v6
Engine: 5.0/5.7/2.8
Transmission: 5 spd in two stock auto in other tw
Axle/Gears: stock
just wanting to invest in transferable headers so if i get a lt1 or 400 block if i can reuse them and also does any one know if you can use a 6000 peak roller cam for a 305 on a lt1 or 400
Old 08-02-2010, 04:56 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: will aftermarket headers for a 89 lo3 fit an lt1 or a 400 block
Yes, headers for one small-block chevy will bolt to almost any other small block chevy. However, headers that work with a small 305 TBI will be too restrictive for a larger 350 LT1 or 400 SBC. Unless you get the bigger good headers now, but those wont be optimized for the 305. Personally, I'd just wait and get everything all at once.
Old 08-04-2010, 02:59 PM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
so the hooker 2055 headers would not be good flow for a 350 or anything bigger than a lo3
Old 08-09-2010, 12:23 PM
Kevin91Z's Avatar
Yes the Hooker 2055's are the best 1 5/8" headers out there in my opinion. But the collector outlet is small, so if you can open that up it will help.
midge54
12-27-2019 04:14 PM
camaro71633
09-01-2015 10:24 AM
lakeffect2
08-23-2015 08:44 AM
theurge
08-21-2015 12:46 PM
sreZ28
08-14-2015 07:48 PM
Quick Reply: will aftermarket headers for a 89 lo3 fit an lt1 or a 400 block
