Cherry Bomb
Old Aug 2, 2010 | 08:57 PM
zwanboy104's Avatar
Car: 1986 Trans Am
Cherry Bomb
Am I able to put on a cherry bomb glasspack muffler on my '86 Trans Am but still have 2 pipes coming out the rear of the car? If so, how would I do this?
Old Aug 2, 2010 | 09:21 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Cherry Bomb
with a splitter, factory they all had fake dual exhaust.
GM was to cheap to install 2 cats.
Old Aug 2, 2010 | 10:48 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Cherry Bomb
There are MANY mufflers out there specifically designed to be crossflow... ie, one pipe in, two pipes out, and the exit pipes are on opposite sides. Flowmaster 80 is the probably the most prevalent.
Otherwise you coudl just weld up a Y junction and run a separate pipe the other side.
But I'd suggest you get a crossflow muffler.
Old Aug 2, 2010 | 10:57 PM
zwanboy104's Avatar
Car: 1986 Trans Am
Re: Cherry Bomb
Yeah, I already have a Flowmaster exhaust system installed. But I'd really just like to have the classic Cherry Bombs on without running them out the sides.
Old Aug 2, 2010 | 11:18 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Cherry Bomb
A cheap exhaust tip can be used as a splitter.
All I run are classic CB's on my cars.
But have learned they sound the best as close to the engine as possiable.
Then with a full length tail pipe. if they just dump its sounds awful.
Old Aug 3, 2010 | 07:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Cherry Bomb
82-85 305/5.0 V8 Dual Exhaust Systems (LG4/LU5) had a single cat which went into an intermediate pipe with two exhaust pipes which in turn went to two mufflers (one on each side of the car), both with a tail pipe. Not true duals, but.... My 85 isn't so equipped.
Some later models were equipped with dual cats, but a single intermediate pipe.
JamesC
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
87350gtanj
Aug 8, 2015 10:32 AM
ChevyGuy87
May 8, 2001 02:37 PM
GTA88
Jan 12, 2001 10:53 PM
