Long Tube Hedman Headers and a 5 speed
Old Aug 2, 2010 | 11:17 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
I am looking at buying this set of Long Tube Headers from jegs
Hedman long tube 68460 from jegs
Says its designed to fit with 700/350 turbos
I was wandering if anyone has used these headers with a 5 speed and if its possible to use them????
I dont want shortys and I dont have alot of money
I am building this car on a budget LOL
http://www.jegs.com/i/Hedman/500/68460/10002/-1
Heres a link
Old Aug 2, 2010 | 11:23 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Long Tube Hedman Headers and a 5 speed
I had those headers and hated them. They fit like crap. I had bad exhaust leaks right at the head because the headers were hitting everything which made them not sit flush up against the head. They also did clear my angle plug heads, except that primary number 1 was sitting on plug number 3. I had to cut part of the primary out and rebuild it to clear the plug. Personally I would run shorties any day over those. Not trying to bring you down or anything, just trying to help you maybe avoid some hassles.
Old Aug 2, 2010 | 11:31 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Axle/Gears: 410
I was thinking the same thing but my father is a machinest/fabricater so Maybe I can make them work. I am not running angle plugs
The reason I want full length is because I am not running a hood on the car and want to have some more shine(As I am powder coating them prolly)
Old Aug 2, 2010 | 11:37 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
search for mw66nova, a few years ago he modded a few sets for use with the t5. if i'm not mistaken the driver side collector runs straight into the slave cylinder.
built91Z28's Avatar
I dont know if he could get them to not hit anything. They even hit my tubular crossmember some.
If the nice look is what you really want, Hooker makes a shorty header that is ceramic coated and comes with a ceramic coated Y pipe. Do they make a powder coat that will take the temps of headers?
Old Aug 3, 2010 | 12:19 AM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Axle/Gears: 410
Yes they do. If its done at right places lol. Our drag car has powder coated headers on it for last 3-4 years and havent turned yet
I dont want ceramic headers(For some reason I dont like them)
Im running true duals and I dont want shorty headers I dont like them
Old Aug 3, 2010 | 09:40 AM
blue85305's Avatar
Car: 1984 camaro
Axle/Gears: 3:42
on the stock crossmember some clearancing is required at the control arm mount on the driver side, but really thats not too bad, hell some ls fbody header require clearancing the block. on a side note hedmans have a thinner flange than hookers and in my experience anyway leak more. but if your dad is a machinist/fabricator i suppose you could cut off the hedman flanges at the head and put the hooker flanges on giving you a cheaper header with a thicker flange.
Old Aug 3, 2010 | 09:50 AM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Axle/Gears: 410
yea we could do that. i just want to get it done so i can cruise it this summer. then winter ill build my own headers
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
87iroctheo
Dec 4, 2016 11:47 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
theurge
Aug 21, 2015 12:46 PM
