Installing headers... what am i getting myself into?
Old Jun 2, 2011 | 12:29 PM
  #51
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Installing headers... what am i getting myself into?
no issues. Remember there are also locking tabs on the factory manifold bolts. They are easy, a sharp flat head screwdriver helps to bend the tabs straight. The only issue i had with my headers was the blower box that was in the way on the passenger side and it was really hard to get at that back bolt. I ended up cracking my blower box. Not sure about the Hooker headers but i did my edelbrock headers from the top. I only had to go under the car to saw off the factory ypipe. I hope you have a matching ypipe for your headers.
Old Jun 2, 2011 | 01:05 PM
  #52
DJK90IrocZ's Avatar
Car: 90 Camaro IROCZ
Engine: 5.7L TPI
Transmission: Auto 4 speed
I didnt see anything on some of my bolts...they look like normal bolts. I will have to take another closer look. I was planning on getting the headers on, then drive to the shop down the road(about 3 miles) and then have them fab up a ypipe to match my magnaflow dual cat ypipe( p/n 23479) and then drive it back home to install the magnaflow catback. Would it be easier to remove some of the bolts from underneath and remove the starter?
You also used Bosch 7985 plugs....right?
Old Jun 4, 2011 | 01:57 PM
  #53
ninetyone's Avatar
Axle/Gears: 3:42
THat is what i did. I got a sawzall and cut my ypipe close to where it bolted to the exhaust manifold and drove it to the shop to have them fab up a small piece of pipe to join the ypipe and headers together. I did not have to remove the starter on mine. You may want to further research on here though because you have Hooker headers and I had Edelbrock TES.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
