How do you feel about flowtech's????
Old Nov 9, 2010 | 01:18 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
http://www.summitracing.com/parts/BIG-11116FLT/
I found these and was wondering if anyone has any experience with the fit and such on them?
Old Nov 9, 2010 | 02:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How do you feel about flowtech's????
Good:
-Cheap
-Fairly good fit
Bad:
-Only 1.5" primaries
-Poor Y pipe design
-Variable quality control
Old Nov 9, 2010 | 02:58 PM
MustangTamer's Avatar
Car: 89 Formula Firebird
Transmission: 700 R4
Axle/Gears: 3:27
i have them. they fit great and are a great improvement over stock.
Old Nov 9, 2010 | 04:00 PM
Axle/Gears: G92
Originally Posted by Apeiron
Good:
-Cheap
-Fairly good fit
Bad:
-Poor Y pipe design
They are really cheap but yes they are small and no 3 in collector also.
Anyone know a good cheap shorty or longtube that works with a t5 and y pipe, I would buy headmans but no one makes a y pipe and they need mods to the collector.
Old Nov 9, 2010 | 10:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Hedman makes a Y pipe for their headers.
Old Nov 9, 2010 | 11:06 PM
Axle/Gears: G92
I was talking about the longtubes.. I didn't know they made one though.
Old Nov 9, 2010 | 11:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Then no, there are no off-the-shelf Y pipes for Hedman long-tubes. Stick with the shortys anyway, there's no advantage to long-tubes on a street car that makes up for the disadvantages.
Old Nov 10, 2010 | 07:29 AM
Axle/Gears: G92
If built right there are no disadvantages.. Plus the long tubes are cheaper then the shortys. Longtubes will make more power... I prefer longtube headers always.
Old Nov 10, 2010 | 08:19 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Come back and tell us there are no disadvantages after you've put a set on a thirdgen, especially one with an automatic.
Even if you built it right and managed to lose no ground clearance (next to impossible with an automatic), the fabrication hassle to do so is a disadvantage. The power gains, if any, aren't all that substantial and don't make up for it. Long-tubes will get you bragging rights, but that's about it.
Old Nov 10, 2010 | 08:56 AM
Axle/Gears: G92
I thought the t5 would be harder with the y pipe and longtubes cause you have to modify the collectors etc. I will be putting longtubes on my auto car but this thread is about my 5 speed car.
What are the best bang for the buck shorty headers? Something cheap, flows good, and has a good y pipe with good clearance then?
Old Nov 10, 2010 | 09:06 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Hooker 2210s are long-tubes and clear the slave cylinder just fine.
The problem with long-tubes isn't even the header, it's the rest of the exhaust system. The collectors dump up between the frame rails, so you have to run tubing under the frame rails to get it to the back of the car. There aren't many ways to do this without losing ground clearance. With a manual transmission, you can run the pipes back inside the rails on either side of the trans and build a new transmission crossmember to clear the pipes and keep the loss to a minimum. The body of an automatic is too wide for this. There's no room between the trans and the frame, so the only way to do it would be to cut up the frame rails.
Old Nov 10, 2010 | 09:15 AM
Twin_Turbo's Avatar
Who knows the part numner of the long tube swept headers that run in front of the oil pand and the pass side sweeps along the starter, the 2 combined run just like the stock system, along the passenger side. Was it a hooker or hedman header? I swear it was a hooker but can't seem to find them. They were full length, 3" collectors, 1-5/8 primaries.
Old Nov 10, 2010 | 09:42 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I can't find them right now either. I thought they were only 1 1/2" primaries though.
Old Nov 10, 2010 | 11:04 AM
Axle/Gears: G92
Intresting...
Never seen these.. Would like too.
Old Nov 10, 2010 | 01:17 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Eddlebrock tes headers?
Old Nov 14, 2010 | 06:23 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I just took in a set of Flowtech shorties in on trade. Thinking of using them on my 305 when I do the V8 swap. What Y-pipe do you use with these?
Old Nov 14, 2010 | 11:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The one they come with, usually.
Old Nov 15, 2010 | 12:13 PM
Camrs89's Avatar
Mine didnt, but then again I got it used. You know if you can buy just the ypipe?
Old Nov 15, 2010 | 01:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Looks like it... http://www.summitracing.com/parts/BIG-11102YFLT/
Old Nov 15, 2010 | 01:58 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
im currently running flowtech shortys on my 355 T-5 with their matching y-pipe which flows through 2 inline chambered mufflers out a single exit (infont of the pass. tire), dual tip pipe and i must say, i have a ton of low end torque, not to mention, the car has a sound coming out of it that scares even the newer generation muscle cars. in fact, id give alot of credit to the exhaust for my light to light win against an 07 Mustang GT a few months back. just my 2 cents.
Old Nov 15, 2010 | 10:11 PM
Prowlincamaro's Avatar
Car: 1988 Iroc-Z
Transmission: 700-R4
Axle/Gears: 2.77
Well I've been running these with the Y pipe for 2 years now. I'm Running a 350/auto combo and they do make a decent gain in power over Stock. But having said that the fitment is poor on the Y section. Plus its not really a Y, the passenger side just T's in with the Driver side, so flow isnt really all that great. Mine came Painted black as did the Y and both are very rusty. It didnt take 6 months for the paint to bake off of both, so i would suggest some Coating or Header paint before install. For the price though overall they are good.....not great but good.
Old Nov 16, 2010 | 07:05 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
I like the cleaner look of the hedman 68470's I have. they fit and sound good. I just dont like the way the flowtechs have the one tube bend up and over.
Old Nov 16, 2010 | 08:44 AM
Axle/Gears: G92
You mean the ones I sold you? Lmao
Old Nov 16, 2010 | 09:44 AM
kd5icr's Avatar
Axle/Gears: Stock
Oh hell yeah. I had them blasted and now I am curing the VHT paint. They look good.
Old Nov 16, 2010 | 01:05 PM
Axle/Gears: G92
Cool! Glad you got use out of them. They sat for a few years lol. I think I'm gonna go longtube on both my cars Now.
Old Nov 20, 2010 | 02:55 AM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
I've got them with the matching Y-pipe. Noticed a pretty big difference over stock. I had to splice out a section of the Y-pipe right below the center of the engine cause it was too wide. Had to have an exhaust shop weld it back together. Came with black paint, that I removed with paint stripper and re coated with high temp paint. Been about 6 months and no rust on them yet...
Old Nov 27, 2010 | 07:34 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
You're gonna wanna eyeball the inside of the passenger side Ypipe flange. Mine was really poorly cut, big ol' overhang of metal where they just punched a 2" opening through the pipe and welded the flange on afterward. It could really use some cleaning up.
Old Nov 27, 2010 | 08:10 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
I used to have those headers and they were pretty good. For $100 I had a muffler shop fab the y-pipe, no need to fight with the pre-made y. The best thing about these headers is the ability to change all the spark plugs from the top. The only plug you will have a problem with is #6, but its not too bad lol.
Old Dec 30, 2010 | 08:35 PM
dp_Z28's Avatar
Car: 86 Z28, '06 Z-71
Engine: 350/trickflow heads
Transmission: 700R
Axle/Gears: 7.625/ 3.73's/powertrax locker
My flowtech's had a hole in one of them when I bought them new.(poor welds)
Old Dec 30, 2010 | 08:46 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Haven't used a set of flowtechs in a thirdgen but I have installed them in several other cars. Fit has actually been surprisingly good, but material is thinner and their paint quality is pretty much awful.
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
