Gasket recommendations
Car: 1991 Camaro RS being built
Engine: N2o Injected 350
Transmission: Reverse Manual Valve Body 700r4
Axle/Gears: 3.73 Torsen
Scored on a set of used but in good condition hedman headers AND y-pipe on craigslist for $100. What's a good gasket to use for headers? I see copper ones everywhere and I've also heard about the Remflex ones but they're still somewhat mysterious to me.
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Gasket recommendations
always been a fan of copper or aluminum gaskets on headers. they give a better seal and are very useful when you've got a less than perfect flange (little warped or rough). they definitely hold up better than paper gaskets.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
+1. Ive always had excellent luck with a pack of fel-pro manifold gaskets. I usually spread a thin layer of the red rtv on the header side before installing them.
The key is to keep checking your bolts to make sure they dont loosen up over time.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I also use RTV but the copper one, though lately I been using the RTV copper spray on stuff, works pretty good and much cleaner to apply to boot.
Engine: 4++,350 & 305 CIs
Fel-pro performance gaskets 1404 1405 1406 1407. several others available
I'll never use anything else.
I have used one set of these on several combos.
use 1" long bolts with anti-size also.
