hooker headers 2055's prob!!
Old Nov 27, 2010 | 04:11 PM
ecalderon's Avatar
Car: 1987 Iroc-z28. 5.7
Engine: 5.7 350 Engine
Axle/Gears: ???
i just went 2 the shop. the new hooker headers i bought wont fit....! they are 2055's. with a 3'' collector. now, the problem is that the collector wont fit through the oppening between the transmission spot and one of the other parts on the other side. the guy in the shop showed me when he had the car lifted. not only that but when he took the stock headers off he cut the air valve line! assuming the hookers would fit. now i have 2 wait till monday for them 2 fix it!!!! anyone know if there are headers for my car??? when i ordered the ceramic hookers they said 86-92 camaro 5.0-5.7. my car is an 87 iroc-z. HELP!!!
Old Nov 27, 2010 | 04:43 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: hooker headers 2055's prob!!
Ive run those headers and they fit my 89 iroc.
I know plenty of others that have run them too.
Tell your mechanic to stop being a lil bich and make them work
Old Nov 27, 2010 | 08:00 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
First of all. MAN UP! Do it your self, its not hard! Just annoying.
These headers fit. I have them on my TransAm GTA. They were on the TPI engine, then I used them when I converted to a stealth ram, and now they are on the same car with my LT1 swap.
They do not fit easily. In some cases many things must be temporarily removed to make room to slide the headers in. They don't always go in from the bottom, though I think the driver side does. Passenger side only comes in from the top I think.
But its been done.
These headers DO fit our cars, there are probably at least a hundred members on these boards who have them.
See the install gallery below where i did heads/cam/intake/headers in a single day.
http://gallery.me.com/thirdgen89gta#...lack&view=grid
Old Nov 27, 2010 | 11:45 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
keep in mind your motor mounts are probably worn out and causing your motor to sag and ruining some of your clearance. dont blame the headers.
Old Nov 28, 2010 | 12:16 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
2055's don't have 3" collectors, they are 2 1/2"
Old Nov 28, 2010 | 01:15 AM
ecalderon's Avatar
Axle/Gears: ???
Thirdgen89GTA believe me when i tell u i wanted 2 do it by myself. i love learning experiences. but the situations where not right 4 the moment. its my daily driver, plus the cat was welded to the y-pipe. i have no idea how to weld or have the tools to do so. i had money so i wanted a pro shop 2 do it. now i'm in a tough situation because of this. and the hole is 2 1/2. the part that wouldnt go through was were u flange the y-pipe 2 the header.im just realy confused by the whole situation....had a bad day all day 2day bcuz of this
Old Nov 28, 2010 | 02:03 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
read again what I said above, motor mounts cause issues like this!
Old Nov 28, 2010 | 08:48 AM
wilnuts88's Avatar
Car: 1988 IROC-Z
Engine: 385 Miniram/Holley HP EFI
Transmission: Probuilt TH-700R4
Axle/Gears: Moser 12bolt 3.55
I bought a Probuilt tranny a while back and my 2055s would not fit either. He gave me a 700r4 that had, what I call "ears" at each side of the tranny causing my collector to hit. I put my old tranny and new one side by side and compared. So to make it work, I carfully cut the ears off, I also called him to make sure it was ok. I don't know if this is your problem or not, but other then that, mine fit perfectly.
Old Nov 28, 2010 | 03:25 PM
ecalderon's Avatar
Axle/Gears: ???
yea thats exactly what was in the way. how did you cut this? do u have pics??
Old Nov 28, 2010 | 03:38 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
so your tranmission has been replaced before because stock transmissions in thirdgens didnt have those ears
Old Nov 28, 2010 | 05:20 PM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
My 88 gta has the ears on the bell housing. purchased a performa built and the ears were cut off. So i lost the mounting holes for the plastic inspection cover. How ever my 2055 cleared easily with both trannys. I had new motor mounts though!!!!!! You could cut or just clearance where needed. Sawzall or grinder to clearance.
Old Nov 28, 2010 | 05:29 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
I've had to cut the ears off for headers before, & it wasn't even a 3rdGen.
Old Nov 28, 2010 | 05:30 PM
mightymaro94's Avatar
DON i dont wanna argue with you (as you always seem to be spot on with your info) but according to hooker they are 3inch collectors... but as mentioned before ... they will go they just may need a little "motivation" lol
Old Nov 28, 2010 | 05:48 PM
wilnuts88's Avatar
Car: 1988 IROC-Z
I just used a rotozip w/ metal blade and cut as needed. Sorry no pics.
Old Nov 28, 2010 | 06:11 PM
ecalderon's Avatar
Axle/Gears: ???
ok. well my car is still in the shop. i'll b sure 2 tell the mechanic dude about the ears....and im not sure if the tranny has been replaced b4?? the one i have now has problems. im not sure. also i'm pretty sure my engine is missing a mount. had a 5.0 but got replaced with a 5.7. maybe the dude i bought it from didnt put it in right. my friend has said my engine moves a lot when i shift. so..... :-O
Old Nov 28, 2010 | 08:05 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
this, they're not really hard. hell my driverside header went in from the top with the motor still bolted down.
Old Nov 28, 2010 | 08:32 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
I hope your not missing a mount. That could be very bad. Replace it ASAP, it's not hard or expensive.
Old Nov 28, 2010 | 09:56 PM
ecalderon's Avatar
Axle/Gears: ???
ok so the ears on the bell housing, i can cut? and how much? mine are like a round triangle type. just enough for the collector to fit through? and what is the "ears" for? i wont need them and or use them 4 anythning...?
P.S. guys. i really apreciate all the help and advice... i love you guys!
Old Nov 29, 2010 | 06:49 PM
ecalderon's Avatar
Axle/Gears: ???
hooker headers 2055's prob!! HELP!!!!
So....the mechanic was being a little "******". said he didnt wanna cut the ears because your not supposed to and this and that. my car was in his shop 4 days and nothing was done....no headers, no tips, no flanges on the cat. all they did was f*&^ up the car by breaking the stock headers air tubes. im completlie dissatisfied. is there anythn i can do? and will i b able to run the car on the stock headers without the air tubes??? atleast to get it the hell out of the shop b4 they do anythn else 2 it
Old Nov 29, 2010 | 07:20 PM
Re: hooker headers 2055's prob!! HELP!!!!
You can get it out of there, however there MAY be a labor charge. I'd fight it, they didn't do the job they said they would, and they damaged your car.
I can't say one way or the other as to how your air-tubes are damaged. These come directly off the exhaust ports so there IS a possibility of an open flame.
If there is any charge, I'd try and fight it.
Old Nov 29, 2010 | 07:21 PM
Does anyone have a pic of these "ears"? I've never seen one, and I've had some 700r4s from quite a few different vehicles.
Old Nov 29, 2010 | 10:17 PM
trocustoms's Avatar
Old Nov 29, 2010 | 11:00 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Honestly..Id go in the shop and just ask if you can cut it yourself and have them finish the job they quoted you.I dont recommend running the stock manifolds with the broken air tubes..for one..exhaust fumes that close to the motor and venting under the hood will be a smokey ride home.
Get in there..cut the ears yourself..they arent liable for that by any means..and then they can get back to work.The headers fit our cars beautifully..Ive re-used mine 4 times around..but then again..my motor was dropped in with the headers bolted on lol and never had issues with it around the tranny.Im also using poly motor mounts
Old Nov 30, 2010 | 12:01 AM
Originally Posted by trocustoms
You had one too many HTTPs.
Old Nov 30, 2010 | 12:36 AM
TTmonteSS's Avatar
Car: 85 monte ss
Engine: 331 twin turbo
Axle/Gears: 3.73 posi 7.5"
cutting the ears on 700r4 and 200-4rs are common with 2 1/2" and 3" collectors on alot of the V8 s10 swaps. just to tight to fit the flanges between the trans and frame. a sawzaw should do it or pull the trans and use a good grinder and a cutting wheel.
Old Nov 30, 2010 | 01:08 AM
Dyno Don's Avatar
Maybe two different versions, the ones I have installed were all 2 1/2" with a 1 3/4" hole, I always had to cut them open.
I have a picture somewhere but I can't find it right now.
Old Dec 3, 2010 | 11:22 AM
DRock89RS's Avatar
Car: 1989 RS,1991 Z28
Engine: TargetMaster 350, L98 350
Axle/Gears: 10 bolt posi 2.73s, and 3.23s
lol thats good. thats why i dont have anyone do any work on my cars unless its my brother helping me... just end up paying for someone elses mistakes
Old Dec 3, 2010 | 12:36 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Agreed...the hole opening is around 1.9" from what I remember. I cut mine to 2.25" before selling them. Y pipe was 2.5" to single 3". Shouldnt have a 3" collector on 2055's (shorty smog legal AIR fittings headers)
Mine fit my 89 just fine. They are shortys, they shouldnt be that hard to get in the engine.
redformula88
Oct 14, 2015 06:08 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
hdis2002
Sep 8, 2015 02:52 PM
