Hidden Exhaust tips on Cat-back kits? Which ones?
Old Jan 4, 2011 | 06:14 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Does anyone know which cat-back exhaust kits come with the factory style hidden down-turned exhaust tips?
The only one I can find is Hawks.
In the days of all cars including Hyundais and Kias having large chrome dual tips I kinda like my hidden tips.
Old Jan 4, 2011 | 06:17 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Hidden Exhaust tips on Cat-back kits? Which ones?
Me too as I like the 'sleeper' look. I have a Hooker cat back; however, I kept my OE tail pipes.
JamesC
Old Jan 4, 2011 | 07:27 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
JamesC
is it because you too are a ' sleeper ' , ( GOTCHA ) you knew i was waiting .
Old Jan 4, 2011 | 08:30 PM
JamesC's Avatar
Okay, Uncle, you're goin' down .
JamesC
Old Jan 4, 2011 | 09:43 PM
UNCLE TOM's Avatar
JamesC
i would expect nothing less . good to do to battle with an armed person . i refuse to have a battle of wits with an un-armed person . back to subject i have magna flow # 16829 S/S system on my car , i like the looks of the tips sticking out the rear . just my thoughts . good luck .
Old Jan 5, 2011 | 09:29 PM
rs coastie's Avatar
Car: 91 camaro rs
Engine: tbi 305
Transmission: 5 speed
I would go with whatever exhaust sounds best to you. you can always switch the tips for a factory style turn down cheaply. as far as kits that come with that look, gmmg without the optional tips, and edelbrock if i remember correctly. not sure what else
Old Jan 7, 2011 | 11:10 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If you dont mind only having one outlet, flowmasters 3" single sits up behind the GFX and is essentially invisible if you set the rear mount to the right hight. I have it, and love it. No frills, cheap, and it gets the job done.
Edit: I think their american thunder kit is also available with stock style pipes. Muffler that comes with it sucks, tho, so it sort of self defeating when you have to put another in its place.
Old Jan 7, 2011 | 11:19 AM
Car: 88 Camaro SC
Engine: SFI'd 350
JamesC
I think these can also be ordered from flowmaster or summit. I know they sell some of the stuff seperately, if you know the right PNs. Mandrel bent, and not all rusty like the factory ones will be when you go to get them off.
Old Jan 7, 2011 | 11:23 AM
Stephen's Avatar
Car: 87 GTA
I've thought of doing an oval piped side exit, to get rid of my rear exhaust tips.
Pic of my TSP Rumbler Cat-back
Old Jan 7, 2011 | 11:45 AM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
I have the Flowmaster Force II on my Camaro, It's a single out 3 inch system with a 30 series muffler and the tailpipe is hidden. It's not to loud and has a great tone. IMO.
Mark.
Old Jan 7, 2011 | 11:18 PM
Dennis-Z28's Avatar
I noticed those single outs. Its a thought, I like the idea just not 100% sure I want to part with the duals.
I already have the Flowmaster muffler on my car so another option is to just replace the cat to muffler section to gain the mandrels. Kinda wanted shiney new tip section too though.
Old Jan 10, 2011 | 08:47 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I bought the Dynomax stock replacement tips for my car. Part #'s are WLK-43243 & 43244. Dynomax also sells the intermediate (44063) and over-the-axle (43248) pipes too if you want to piece together the cat back.
Old Jan 10, 2011 | 09:14 AM
Pocket's Avatar
Car: 91 Trans Am
I have LM1
I cut the tips even with the bumper cover under the car and you can barely see them without being eye level. Dont see why that wouldnt work for most catbacks too
Old Jan 10, 2011 | 11:42 AM
87350IROC's Avatar
Car: 87' IROC
Edelbrock catback.
Old Jan 10, 2011 | 01:31 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I have the Flowmaster 3" 1 out... I used heat primer / paint to paint the out pipe black...
The one in / one out will flow better than 1 in / 2 out (I know there are better flowing than Flowmaster), but if you're hiding it anyway, why keep the fake duals?
Now if I could only make my Jet Hot Ceramic Coated Y pipe a little more stealth
Old Jan 14, 2011 | 01:20 PM
85_ZED28's Avatar
Car: '85 Z28
Has anyone here installed stock style tail pipes on the 16829 Magnaflow catback? It looks like it has 3" outlets on the muffler which I guess would require reducers to fit stock pipes?
Old Mar 5, 2011 | 12:14 AM
Dennis-Z28's Avatar
Interestingly I found this article today in my local paper:
http://www.vancouversun.com/news/tod...015/story.html
Old Mar 5, 2011 | 09:18 AM
86sc5's Avatar
Car: 86 sport coupe
Engine: 355
Transmission: 5speed
Axle/Gears: 3.73 detroit locker
I am using a 3" in 3" out ultraflo. No tailpipe, just a 10" long turndown angled back a little so it doesn't point straight at the ground.
Old Mar 5, 2011 | 06:46 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Cut back 3in.Flowmaster tips on the American Thunder Cat. back/80 series muffler. The tips are not invisible but you do need to be on your hands and knees to see them. Its not exactly a sleeper look nor dose it sound like one.
Old Mar 5, 2011 | 11:22 PM
notoriouscamaro's Avatar
Car: 92 RS 5 speed
Engine: 5.0L TBI
Axle/Gears: 9 bolt rear
Custom! A good exhaust shop will make a cat back hide-away! Usually for cheaper than the cat-back you find in the aftermarket..
Old Mar 6, 2011 | 08:36 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
crappy picture, but here's mine, single 4", but i built it, its not a kit
Old Mar 6, 2011 | 09:27 AM
86sc5's Avatar
Car: 86 sport coupe
Engine: 355
If you don't mind crush bends. Alot of exhaust shops don't mandrel bend. Mandrel bends flow much better.
Old Mar 7, 2011 | 03:23 PM
Car: 92 RS 5 speed
Engine: 5.0L TBI
Ill post pics of mine when i get a chance.
Old Mar 8, 2011 | 09:11 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Originally Posted by 87350IROC
Edelbrock catback.
Yes the old-school Edelbrock performer series cat backs have the closest match to the stock tail pipes. They are slash cuts with the ends nipped off, exactly like the originals were. I've had 2 kits, one on my IROC years ago and I currently have one on my TA.
Beautiful car by the way.
Old May 28, 2011 | 11:33 PM
Dennis-Z28's Avatar
I ended up having to get something on short notice and went with the Flowmaster. In all I am actually happy with it. It is much ;ess blingy than I expected and quite low profile. You have to stand back quite a ways to even notice it.
Old May 28, 2011 | 11:36 PM
Dennis-Z28's Avatar
Hooker headers are nice too.
Old May 29, 2011 | 12:15 AM
Engine: TBI,5.0
Looks really nice and what a beautiful car.
Old Jun 9, 2011 | 02:13 AM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Old Jun 10, 2011 | 03:38 PM
85_ZED28's Avatar
Car: '85 Z28
Originally Posted by fiream
That sounds nasty! What are the specs on the engine?
Old Jun 10, 2011 | 09:25 PM
fiream's Avatar
Engine: 400HP 350
Engine
1989 Chevy 350 Block (4 bolt mains)
SpeedPro flt top pistons
LT1 Connecting Rods
ARP Hardware
906 Casting Vortec Heads (clearanced for .500 lift)
Compcams valve springs
Scorpion Roller rockers (1.5 ratio)
Compcams Double roller timing chain
Compcams Dual Energy 275DEH Cam
Weiand Stealth 4BBL intake (for vortec heads)
Edelbrock Thunder AVS Carb 650cfm
Edelbrock TES Headers (2.5" at the collectors, 3" y-pipe)
No Cat
Factory 3" midpipe
Hooker Aero Chamber muffler (3" in, dual 2.5" out)
Factory 2.5" Tailpipes
Old Jun 13, 2011 | 03:41 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
if you Buy a EL CHEAPO kit maby
and the fake duals.. well thats a Hot Rod Trade Mark!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
NinjaNife
Aug 23, 2015 11:49 AM
drathaar907
Aug 6, 2015 04:20 PM
