Installing Headers!!
Old Feb 3, 2011 | 09:19 PM
jcon104's Avatar
Just wanted to know what i am getting myself into.....thinking about installing headers easy right?? Is it still easy with the engine still in the car, i have done it with the engine out before but never with it in, is it possible to reach all the bolts...and is it even worth trying?
Old Feb 4, 2011 | 12:08 AM
EvilCartman's Avatar
Car: '82 Z28
Re: Installing Headers!!
I've installed Edelbrock shorties and Hooker long tubes with the engine in, no problems. Read the instructions that come with whatever you buy, some don't and they miss out on little tips that make things go smoother.
Old Feb 4, 2011 | 12:18 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
It is ABSOLUTELY worth it! The low end torque gains from my hedman 68470's alone was worth it! Just be really patient! I still have all the emissions equipment in my '86 IROC so changing the rear sparkplugs now has to be done from underneath, but other than that, no problems! Good luck!
Old Feb 4, 2011 | 06:53 AM
jcon104's Avatar
so it is def possible to get to all the bolts, i just wanted to make sure it could be done were most of the bolts got from underneath the car or under the hood.
Old Feb 4, 2011 | 08:52 AM
torque_is_good's Avatar
there will be items in your way. You will need to remove them to make it simpler. You should remove the starter. You will be disposing of the stock Y pipe and installing a new y pipe so use a sawzall instead of messing with frozen bolts.
You will remove the motor mount bolts and you will be raising the engine. You may even need to remove the one tranny mount bolt or loosen it so you can raise the engine even more.
As long as you are OK knowing that many items will need to be removed as "make-ready work" then you are going in with your eyes wide open.
Old Feb 4, 2011 | 10:00 PM
jcon104's Avatar
thanks for the help guys....the smart thing would have been to do it 2 weeks ago when i did my t5 swap oh well live and learn
Old Feb 4, 2011 | 10:12 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
And if you have never done small block chevy headers before, coat the gaskets with RTV...you'll thank me later. And I would invest in stubby wrenches 5/16 or 7/16 depending on which size your header bolts end up being.
Old Feb 4, 2011 | 11:24 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
its not quite easy but not terrible. If i can do it you can lol
Old Feb 5, 2011 | 02:53 AM
Car: '82 Z28
It is easy, just takes a bit of time sometimes. Also, I never had to lift the engine and was able to get everything from the top. Headers themselves depending on what you buy might drop in from the top or bottom. My long tubes went in from the bottom like nothing.
Old Feb 5, 2011 | 06:14 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Do yourself a HUGE favor, spray all the manifold bolts down the night before with PB Blaster. You will need a breaker bar too. I did everything from the top,i only had to go under the car to cut the stock ypipe off. Oh, and by the way keep a sawzall handy.There are also locking tabs on some tpi car's manifold bolts making it difficult to get a socket around. Just get a small flathead screwdriver to bend them back. I did not have to jack up my engine or remove my starter either. I installed Edelbrock Tes headers. Let me know how it goes.
Old Feb 5, 2011 | 06:17 PM
ninetyone's Avatar
Axle/Gears: 3:42
Oh, and most importantly. You will need 90 degree spark plug boots/wires. Shorter plus too. I used Bosch 7985. Be really careful not to break them when dropping in your headers.
Old Feb 5, 2011 | 06:21 PM
ninetyone's Avatar
Axle/Gears: 3:42
You better make sure you have a matching ypipe ready that is designed to bolt to those headers too. It will be 99 percent easier after you get the headers installed.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
