emissions failer can someone help
Old Mar 5, 2011 | 11:28 PM
z28 350's Avatar
okay lets get started i got a z28, tpi, 5.7l, 350, 1991 okay the car fails emissions by alot. so can anyone help with that i have new cats they work, i have put new plugs in, new wires for the plugs, new distributor and cap, a new o2 sensor, new maf sensor, new iac sensor i put all these new thing on it and i checked the injectors and there all in there right range im just get way to much fuel i can smell it out the back of the pipes.
Old Mar 6, 2011 | 06:37 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: emissions failer can someone help
check engine light coming on? Check the Coolant Temperature sensor. It may not be reading coolant temps correctly. Therefore making the computer think the car is cold when it is hot. So then it dumps a ton of fuel into the engine and it doesnt burn properly. But how is the car running? Also check your egr function. What #'s are high on the test results? To really get the best advice you should post your #'s on here so the guys who know thier smog #'s better can chime in and help you.
Old Mar 6, 2011 | 10:45 PM
z28 350's Avatar
i have changed the coolant sensor as well and my numbers are
Hydrocarbons (HC)-- carbon monoxide (CO) ---oxides of nitrogen (NOx)
to pass 0.80-------- 15.00------------------- 2.50
im at --19.87------- 27.50------------------- 0.33
---------FAIL------- FAIL-------------------- PASSED
the one i passed say the EGR is working right and i dont know how to fix this
Old Mar 6, 2011 | 11:04 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
hmm a lot of unburnt fuel. does the car feel like it is running good or is it running rough?
Old Mar 6, 2011 | 11:15 PM
z28 350's Avatar
well hard to tell it run pretty good but kinda bad
Old Mar 6, 2011 | 11:18 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
pretty good but kind of bad? Is taking the car to a reputable test and repair station out of the question? did you check the compression when you had the spark plugs out?
Old Mar 6, 2011 | 11:24 PM
z28 350's Avatar
it runs rough to me but my mechanic said it runs fine, and nothing out of the question and i didnt check the compression
Old Mar 6, 2011 | 11:43 PM
z28 350's Avatar
the one thing i know if your cats are working and EGR then you can pass emissions no matter what but there cant be leaks and just change the timming and makes the car run hot but i want it to run right and i have leaks at the cat the y pipe fell off that send air to the cats
Old Mar 7, 2011 | 01:38 PM
Deven534's Avatar
Car: 1987 Pontiac Trans Am
Engine: 5.7 350 Tpi V8
i have a 1987 trans an with a 350 tpi V8 in it....im wondering if an egr temperature sensor from a 1989 trans am with a blown 305 tpi would work...
Old Mar 7, 2011 | 01:48 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
how old are your fuel injectors.
Old Mar 7, 2011 | 02:43 PM
Deven534's Avatar
not old...i just put a brand new 350 tpi from the dealer in it. the motor has about 15,000 miles on it
Old Mar 7, 2011 | 03:50 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
smelling fuel means rich......maybe injectors are not the same constant as in the computer....bad fuel pressure...tps set wrong.....off a tooth in the dist.
just some ideas
Old Mar 7, 2011 | 03:57 PM
z28 350's Avatar
so maybe computers messing up or injector need to be tuned and tps is right were do i check fuel pressure
Old Mar 7, 2011 | 04:40 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
valve on the fuel rail
Old Mar 7, 2011 | 05:18 PM
z28 350's Avatar
okay ill check it out then thanks
Old Mar 7, 2011 | 05:39 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Check the base timing. See if it's set at 6°. If you changed the distributor, than the timing has to be checked.
Old Mar 7, 2011 | 06:43 PM
z28 350's Avatar
well i have it loose so when i take it to emissions test i can change the timing to pass all most did
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
