Do I really need 3"?
Old Mar 23, 2011 | 08:19 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
My combo I'm running will be in excess of 500 FWHP. Set of Doug's LT, x-pipe. On motor I should be 425-450 plus a 100+shot on occasion (undecided on size of shot) Will I sacrifice much power if I go to 2.5". Thanks.
Old Mar 23, 2011 | 09:03 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Do I really need 3"?
I think its a must if your going with a single exhausr but if your going with duals i think 2.5 are enough
Old Mar 24, 2011 | 01:12 AM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
With that much power at the wheels, you need at least two three inch pipes. If you are staying with a single pipe look at least at the 4 inch. Otherwise you will have a serious restiction
Old Mar 26, 2011 | 04:49 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Beat me to it...
Old Mar 26, 2011 | 05:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
500 FWHP as in flywheel/flexplate horsepower? Single 3.5" but a 4" wont hurt. Single 3" is really hurting that setup with nitrous IMO
Dual 2.5" is fine.
Old Apr 2, 2011 | 02:02 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
ok so my motor is a 383 with almost 500 hp at the flywheel and planing on over a 100 shot 3" y pipe and 3" from y pipe to muffler would be to restrictive
Old Apr 2, 2011 | 03:55 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
Heres a general outline that helped guide me to my choice. It's from dynomax's website.
Old Apr 2, 2011 | 09:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I've always gone by Vizard's values of 115cfm per square inch of pipe and 2.2 cfm per hp.
single 3" is 7.07 sq. inches. It will support about 813 cfm of exhaust flow. Engine requires about 2.2-2.3 cfm per hp. That means a 3" single will support 369 hp before it becomes a restriction. Duals is good to 738.
Single 4" is good to 1445 cfm of exhaust flow or 657 hp
2.5" is only good to 257 hp for a single and 514hp for duals.
Old Apr 3, 2011 | 10:20 AM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Really good info posted by Orr
Old Apr 3, 2011 | 07:19 PM
Car: 89 iroc
Engine: 355tpi
thanks alot guys very good info
