For anybody considering headers!
Old Apr 25, 2011 | 12:32 PM
WS6Formula5.7's Avatar
Car: 89' Firebird Formula
Engine: 5.7 TPI
Axle/Gears: stock
Hello..this is for the people who are planning to put headers on.. I just installed a set of flowtech headers with matching y pipe and anybody looking for a fast affordable change out i recommend this setup.. i spent the afternoon over the weekend removing manifolds and installing this set and for the most part everything went smooth (would have went smoother if i would have taken a few extra steps but i was shortcutting). The only problem i have with this is that the clearences are a little tighter than i prefer but all in all not to shabby... I just wanted to clear this up for you guys considering this swap because i was looking on here before i did this and there was no real clear answers about the flowtech setup..everybody jumped straight to the more expensive setups as soon as somebody asked about the flowtechs.. If you guys have any questions about the swap let me know...
Old Apr 25, 2011 | 12:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: For anybody considering headers!
Flowtechs fit fairly well, but they've had quality control issues and they're small for performance use.
Old Apr 25, 2011 | 01:19 PM
Engine: 5.7 TPI
Axle/Gears: stock
yes i agree not good for more higher HP motors but good alternative for stock applications or lightly modified.
Old Apr 27, 2011 | 10:07 PM
DJK90IrocZ's Avatar
Car: 90 Camaro IROCZ
Engine: 5.7L TPI
Transmission: Auto 4 speed
WS6...Did you have single or dual cats?
What part# did you install?
Any issue with clearence with the frame, spark plug access..etc?
What cats and catback are you using and how does it perform compared to your stock setup?
Old Apr 28, 2011 | 07:45 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
The only benefit you gain from the flowtech is having longer primary runners. The opening size is actually smaller in some cases than a factory manifold. I'm honestly not sure why they ever made them in 1.5 inch primary.
Old Apr 29, 2011 | 06:36 PM
DJK90IrocZ's Avatar
Engine: 5.7L TPI
So I guess that Flowtechs are not really that great of a header to put on a 350 with a fully ported intake?
planning on installing magnaflow dual high flow cats with the catback system....
Old Apr 29, 2011 | 07:13 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I personaly would not put them on a 350 in general unless it was going in a tbi mud truck or somthing that would benefit from the smaller primarys.. you want a nice flowing header look for 2055 or hooker 2460. they are mid price but flow great for most peoples needs.
Old Apr 29, 2011 | 08:51 PM
DJK90IrocZ's Avatar
Engine: 5.7L TPI
92RS...thanks.....Is there any real differences from those 2 headers?
It sounds that with the Flowtechs having smaller primarys that you might have a slight increase with torque, on the lower end but no high end
Old Apr 30, 2011 | 08:40 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I believe the 2055's come emission ready if you need it and they are ball flange. the 2460 seem to have a little better collectorr, but are not emission ready and are 3 bolt flange.
Old Apr 30, 2011 | 04:55 PM
Fermin91rs305's Avatar
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
I was wondering for all you guys that installed headers what did you do with the A.I.R system....from the manifolds????
Old Apr 30, 2011 | 06:24 PM
DJK90IrocZ's Avatar
Engine: 5.7L TPI
I was just planning on removing it and keeping it in case I would ever sell the car to someone that needs to worry about emissions.
Old Apr 30, 2011 | 06:28 PM
DJK90IrocZ's Avatar
Engine: 5.7L TPI
Hey 92RS....
Did you remove your AIR system?? Did you experience any performance issues like running more lean due to no air going to the cats and headers?
I was thinking of going with the 2460 since I have dual cats and will have to make custom y pipe to fit my dual cats anyways.
I do like the 2055, but I would never be able to use the y pipe to the single cat.....you know anyone that would buy that if I were to sell it?
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
