Stock manifold flange gaskets???
Old May 1, 2011 | 09:47 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Does anyone have the part numbers for the exhaust manifold flange gaskets? They're the "donut" style where the y-pipe connects. I've called my local stores and they all say they dont list the part. I know I've bought them in the past.
Also, the passengers side manifold has this goofy looking spacer between the manifold and y-pipe. Is there a gasket that goes here too?
Old May 2, 2011 | 10:31 AM
Re: Stock manifold flange gaskets???
Donut gaskets are COMPLETLEY generic. There are only 2 styles (tapered both sides, and tapered one side and flat one side), and a handful of sizes (2", 2¼", etc.). They can be either composition or pressed metal powder. A VERY small universe to choose from.
Just take the remains of whatever you have, and match it up. Most gasket lines (FelPro for example) package them in plastic bags which makes it SUPER eeeeeeezie to match em.
I don't recall any of these cars using donuts; seems like they're all a ball flange on the manifold, and a matching flange on the pipes. But I could be mistaken. That's probably why the stores don't list em for these cars. However if you have manifolds that came from some other car, they might fit, but use a different arrangement.
Carb cars have the EFE ("heat riser") valve in the palce you describe; not sure if any of the FI ones did, although in the overlap years, they might have. No that does not require a gasket, although on the flat side (toward the manifold) you could add a flat one if you felt like just having something to blow out later.
Old May 2, 2011 | 08:15 PM
Dialed_In's Avatar
Thank you.
Old May 2, 2011 | 08:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
While carbed cars were equipped with the EFE valve, TPI cars had a simple spacer.
JamesC
Old May 3, 2011 | 09:25 PM
Dialed_In's Avatar
And there is no gasket between the spacer and manifold?
Old May 3, 2011 | 11:01 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
There shouldn't be any gaskets. The driver's side manifold and the spacer on the passenger side have a ball socket machined into them and the pipes are flared to match the angle. The top side of the spacer and the bottom side of the passenger side exhaust manifold are machined flat so there is no gasket needed there also.
If it makes you feel better you can apply a thin coat of exhaust cement/sealer. Just be sure to assemble the exhaust quickly as it drys in a few minutes.
Old May 4, 2011 | 07:47 AM
Dialed_In's Avatar
Okay, I'll take your word for it. Thank you.
Old May 29, 2011 | 04:13 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
My passenger side manifold has a flat side...the y pipe has a flared (cupped) fitting...what do I do there?
Old May 30, 2011 | 11:28 AM
Dens71TA's Avatar
You are missing the spacer.
Old May 30, 2011 | 11:38 AM
JamesC's Avatar
Take note of part 21.
JamesC
File Type: pdf
Old May 30, 2011 | 11:41 PM
Mr Froman's Avatar
Edit- never mind. misread.
Thank you!
transaero
Aug 31, 2015 01:14 AM
Bstrang6
Aug 26, 2015 11:39 AM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
