engine movment/exhuste clearance
Old May 9, 2011 | 11:05 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I have poly motor and tranny mounts I want to know how much movement there is going to be, I'm going to be fabricating a y-pipe and i plan on tucking it up as close as possible to the frame rails. How much clearance do I need to leave between the tubes and frame rails? For engine flex. would something around 1/4 be fine?
Old May 10, 2011 | 12:55 PM
FueledSoul's Avatar
Re: engine movment/exhuste clearance
bump
Old May 10, 2011 | 12:58 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Should be fine, but you can control how much vibration you get at any one point with attachment points to the floor boards. I add hangars any place I want to precisly control distance.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
