HELP me Fix my exhaust rattle. Heat shield.
Old May 30, 2011 | 01:41 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
So when i drive everytime i change gears my exhaust rattles. I belive its my heat shield right above my cat. anyone have any ideas on how to stop the rattling. its very annoying.
Old May 30, 2011 | 01:57 PM
cHEVy hEAVy's Avatar
Car: 1989 IROC Z
Engine: 5.0 tpi. stock [for now]
Re: HELP me Fix my exhaust rattle. Heat shield.
i had the same prob, & i took off the top heat shield on my cat , cus it was embarrassing to rattle everwhere i go. i plan on doing a complete exhaust system (headers, y pipe, the whole 9..) soon. it worried me that it might mess something up to take it off, but ive been on hour & a half rides since i took it off and i havent seen any sighn of anything being affected by me taking it off.
Old May 30, 2011 | 06:40 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
To see if that's actually were the rattle is coming from take a ball of aluminum foil and wedge it between the cats top shield and the shield on the car. If the rattling stops than that's the spot.You could make some small adjustments to the top shield or I guess you could just leave the foil there.
Old May 31, 2011 | 02:08 PM
Car: 91 formula
So today i removed the heat shield right above where my cats once where. I just got back from a test drive and it fixed it. Not one rattle at all. Now my question is would it do any damage driving without it on? Any long or short time effect? i don't have cats on the car and its a duel y pipe setup.
Old Jun 5, 2011 | 09:27 PM
SRichardson868's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
had the same problem but mine was a bad cat had to get a new one
Old Jun 5, 2011 | 11:29 PM
Car: 91 formula
well bad news for me. Had the heat shield off but still here rattles when im at low RPM's it sound really bad. Its I catless exhaust system
Old Jun 6, 2011 | 07:45 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I have the same problem I think anyway.To me it seems to rattle only when there is a load (like accelerating, or going uphill). I think it may my exhaust manifold gaskets. I plan on replacing those and seeing how they help. Maybe it's the same with you?
Old Jun 6, 2011 | 09:56 PM
Car: 91 formula
I don't think it my manifold gasket because the noise is coming right under the car around the ypipe or I Pipe.
Old Jun 6, 2011 | 09:57 PM
chevydrvr's Avatar
Maybe the bolts are losoe where the y-pipe meets the manifolds?
Street Lethal
Apr 30, 2019 12:14 PM
chazman
Aug 28, 2018 03:25 PM
mustangman65_79
Sep 1, 2015 03:51 PM
dyeager535
Aug 28, 2015 08:10 AM
TheExaminer
Aug 26, 2015 04:59 PM
