good v6 exhaust
Old Jun 5, 2011 | 11:02 PM
1987_sportcoupe's Avatar
Car: 1987 Sport Coupe
Engine: Carbeurated 5.7
Transmission: NWC T-5
Axle/Gears: Non-posi 2.73
good v6 exhaust
Replacing my stock exhaust on a 2.8. Any suggestions on good v6 exhaust?
Old Jun 6, 2011 | 01:01 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: good v6 exhaust
Well, I'll tell you, this is my suggestion and two cents.
First, replace the manifolds and y pipe. Your Y-pipe is a really restrictive piece of garbage. If you can, buy the pacesetter headers kit with y-pipe and start there. If the headers are above your budget, then keep your manifolds and have a custom y-pipe made, preferably using a flowmaster y-transition pipe.
Next, if you are keeping your engine stock for the most part, use parts made for a factory TPI V8 car. If you are on a budget, just go to the parts store and get the entire cat back exhaust for an IROC or a Trans Am with a vin code 8 engine. I even use used parts for my V6 stuff because I'm on a budget.
If you have some money to spend, I would buy a high flow cat and a cat back system for the same Trans Am. A stock V6 will improve performance using the V8 setup, and all I had to do was have the exhaust shop make a new transition from my Y-pipe to the V8 cat. Everything else I did myself in the driveway.
Good luck!!
Old Jun 7, 2011 | 05:52 AM
DrexRS's Avatar
Engine: 305 TBI
Transmission: 5 Speed Manual Transmission
Axle/Gears: Stock
Re: good v6 exhaust
On my 3.1 Camaro I had a cherry bomb. It sounded pretty nice for a v6
Old Jun 7, 2011 | 07:53 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: good v6 exhaust
My friends ran a 2.5inch dynomax on his 3.1L sounded really good,
Old Jun 7, 2011 | 09:26 AM
Ellis123's Avatar
Car: 1984 Camaro sport coupe
Engine: 2.8L V6 :(
Transmission: 4 speed auto
Re: good v6 exhaust
what about for the carbed 2.8L from 82-84?
any suggestions?
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
86White_T/A305
Mar 6, 2016 01:48 PM
customblackbird
Oct 1, 2015 04:30 PM
