Header/ engine mount issue
Old Jun 12, 2011 | 03:34 PM
redCamaroblack's Avatar
Car: 1985 Camaro
Engine: 400sb
Transmission: 700r4 auto
Axle/Gears: posi trac, gears??
I recently swapped my 305 for a 400sb in my 85 camaro. I bought a set of headers at a swap meet, and I'm having issues with the front tube on each side hitting the top of the engine mounts on the engine. Could I just grind or cut the top corner off the engine mounts, or do I have to get new headers? I really dont want to put the manifolds back on it, nor do I want to crack a mount...
Old Jun 12, 2011 | 07:05 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Re: Header/ engine mount issue
Are the headers you got specifically for thirdgens? If not then they probably wont work. But if the only part hitting is the front tube you may be able to dent the header for clearance.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Wesly_66
Aug 26, 2015 09:55 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
