2.5" mandrel bent H-pipe true duals with 6" of clearance and Magnaflow mufflers
Old Jun 15, 2011 | 10:27 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
After I decided to go with long tube headers I picked up a set of Headman 68460's here:
https://www.thirdgen.org/forums/exha...ong-tubes.html
Then had them coated:
https://www.thirdgen.org/forums/afte...ings-wood.html
Then ordered some 2.5" mandrel bent pipe:
https://www.thirdgen.org/forums/afte...aust-pipe.html
The bought 2 Magnaflow 10416 mufflers:
Here's what resulted. Tacked and ready to weld:
Fully welded:
Painted:
On the car:
Ground clearance:
Heat shielding the fuel/brake lines and slave cylinder:
Old Jun 15, 2011 | 10:38 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: 2.5" mandrel bent H-pipe true duals with 6" of clearance and Magnaflow mufflers
Cool, I'm looking for a set of headers that will tuck up nicely.
Old Jun 15, 2011 | 10:41 AM
Car: '91 LS6/T56/9"
Engine: LS6
Unless you're making serious HP, those headman headers can't be beat for the price. Of course there's this big argument about stainless vs ceramic coatings...........overall I'm happy and that's what I care about. Also, I only used 1 or 2 pieces of that mandrel bent kit I bought so most of it will be for sale soon.
Old Jun 15, 2011 | 11:07 AM
Car: 1989 Camaro RS
Engine: LH6
Yeah I won't be making anymore than 400 anyway. So those will work perfectly for my set-up.
Old Jun 15, 2011 | 06:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
6" of clearance everywhere? how high is the car sitting?
is that plate on the crossover pipe bolted on with the trans mount? interesting idea, should be fine, but im curious if it will transfer enough heat to burn the trans mount?
Old Jun 15, 2011 | 10:24 PM
Car: '91 LS6/T56/9"
Engine: LS6
No way man! The 7 quart pan is at least 1.5" lower than 6. I was just referencing the clearance of the exhaust which I felt was a decent accomplishment.
The trans mount does not get melted since everything near the exhaust is heat shielded. It probably wouldn't anyway, but I did it as a precaution.
cstrobel65
Sep 16, 2015 11:54 AM
Camaro_383
Sep 11, 2015 11:28 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
