Hooker exhaust?
Car: 92 RS anniversary edition
Engine: 305 TBI
Hooker exhaust?
Yo guys I've got a 92 camaro 305 TBI and I'm going to put typical upgrades on there chip, headers, intake, maybe cam and heads but I need a little advice on this exhaust. http://www.summitracing.com/parts/HOK-16823HKR/ there it is, so i am wondering when I change my engine to a 350 will this still be ok because it says it's for 305's but I dont think it will make that much of a difference will it? and also I hate the tips that come with it so can I just not have those tips on there and leave it or will I have to put different tips on? any advice is appreciated!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Hooker exhaust?
JamesC
Car: 1988 Formula
Transmission: TH-700-R4
Axle/Gears: BW 9 bolt 2.77
Re: Hooker exhaust?
Next... unless you have a manual trans.
You can avoid a LOT of headache by saving up for the matching header and Y-Pipe
http://www.summitracing.com/parts/HOK-2055HKR/
they are tuned length headers that fit well and the Y has a 3"exit to match your new cat back system yes they have O2 tubes use them or hack and fill them.
the only other option to get a 3" exit is a is custom made Y
manual trans have a little more room and full length tuned headers can be used
make sure to search before shopping
Engine: 305 TBI
Re: Hooker exhaust?
well I ordered these http://www.summitracing.com/parts/HOK-16767HKR/ with these headers http://www.summitracing.com/parts/HOK-2460HKR/ which I think will work well
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Hooker exhaust?
i run the same headers, but use a custom y. i dont like the hooker y since it cuts down from a 3" collector to a 2.5 pipe. and the hooker y that is a full 3" is EXPENSIVE.
Transmission: 4L80E/4L80E
Re: Hooker exhaust?
Engine: 305 TBI
Re: Hooker exhaust?
Well I would have ordered those but my car is a 1992 and those headers only go up to a 90's model so I'm not positive but I dont think they will fit?
Axle/Gears: '01 3.42 10 bolt
Re: Hooker exhaust?
actually, i would doubt there is much difference. they both have a 3" collector and the one johnny posted doesn't specify what the Y outlet is. plus, i believe the 2460 has a thicker gauge primary tube.
Engine: 305 TBI
Re: Hooker exhaust?
Hey 87zjeff I see you have a modified 700R4 trany can you tell me a little about it? I was planning on swaping my engine within a year and wondered if what you did with your tranny, how worked or how easy was it? I was thinking of just switching to a posi rear but who knows
The outlet is 2-1/2". It's designed to eliminate the cat and hook directly to an L03 cat-back.
Which means the ID is smaller. The tube size is OD, and thicker gauge will reduce the ID.
You may want to ship the headers and Y-pipe back and get the 2055HKR's.
Engine: 305 TBI
Re: Hooker exhaust?
Could I just modify the Y-pipe I am getting instead of going through all the hassle of sending it back?
Car: 1988 Formula
Re: Hooker exhaust?
Now you will need to make a custom Y if you want a 3" exit.
2hours in a shop at 60$+ per hour
only way to get the 3" hooker Y is to buy it with the headers
tuned headers would of made more power but, yours are a bit thicker so heat/sound and header life will be increased get them coated and they will out last the body.
I was just directing you to a well tested/fitted 3" system that U can bolt on 100% in your drive way and it is smog legal (with a CAT)
I Just trashed 450$ worth of 1 year old exhaust crap!!
like others I see the light of the Hooker system
As Johnny is trying to say, modifying the Y-pipe will cost you more than shipping the headers and Y-pipe back. And, most likely you'd have an inferior product when done.
Hotrodboba400
Dec 10, 2019 07:07 PM
Chevykid810
Sep 28, 2015 12:57 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
