Need new header gaskets... suggestions??
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
I have the stock heads and edelbrock headers. I was wondering what were the best gaskets and what type to get. Part #'s would be great. I also need the donut type that fit in the collector. I don't want to order the wrong type of gasket that doesn't fit.... Thanks!
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
Re: Need new header gaskets... suggestions??
I kept blowing the paper gaskets on my hookers until I bought some Percy aluminum header gaskets. These work great! there are other brands also but the aluminum seals alot better than the other materials IMO
Car: 1991 Z28
Engine: 5.7 TPI L98
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i have gaskets with the carbon foil inserts in them, forgot who makes them, the paper gaskets just blow out, i've blown out the aluminum ones also, you need to invest in the locking header bolts, if the bolts come loose you'll blow out the gaskets
Engine: 4++,350 & 305 CIs
Fel-pro 1504 thru 150? is what you need. I think the 1504 is the stock size stuf.
also use 1" long header bolts (if you can, i think they fit fine) with reduced head size and put anti-seize on your bolts..
Car: 1987 Trans Am
Engine: LQ9/L92
i've had good luck with the percy aluminum gaskets and the mr gasket copper ones. had a bad problem with blowing out the paper ones on my last setup, put in the coppers and never had the issue again.
percy's seal 4 good or mr gasket dead soft aluminum
the ticket is dead soft aluminum which is what percy's are as well
i've ripped out more junk fel-pros than i care to recall and now only use dead soft aluminum. It's worth the extra $10-$20 you pay.
