Does anyone build Custom Y-Pipes?
Car: '91 Camaro RS
Engine: 383 Stoker
Transmission: Pro-Built 700R4
Axle/Gears: 3.42 Detroit Locker Posi
I've checked with all my local muffler shops and NO ONE can bend or build a custom 3" y-pipe. Does anyone on here make a y-pipe for there setup? I'm going to be running Hooker 2460HKR shorty headers with a 3" Magnaflow cat and exhaust system. I'd pay someone to make me a y-pipe if someone can bend and weld.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Does anyone build Custom Y-Pipes?
If you have tools and a crap welder it should be easy enough to order piping, fit, cut, and tack it and take it to a shop to have it finished. That's what I did to get my Mufflex setup to fit correctly. Else try contacting the local auto service places they might be able to make you one. I would shy away from anyplace wanting to do normal kink type bends.
Car: '91 Camaro RS
Engine: 383 Stoker
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
I'm pretty sure either straightline performance or finish line performance does mandrel bends.. both those shops are out Joliet way...
If you have a friend with a welder making a y pipe is pretty easy...
I fabbed one earlier this year a true 3 inch to 4 inch for my formula all I did was buy bends from summit and tinker toy it together...
If you wanna buy my whole exhaust we could maybe work out a deal...
Lemme know what you wanna do and I'll see if i can help
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I think a 3 inch y pipe maybe a little overkill. You should look at one of Dyno Don's 2.5 inch y pipe. Best one on the market, I have one on my car, fits and works great
Car: 89 Formula
Why would I want to use a 2.5 inch y pipe when I have 3 inch header collectors and a 4 inch exhaust?
Car: 1988 Camaro
Engine: 383 Stroker
you may lose some torque when going to a 3 inch y pipe. May be to much for your combo.
3" won't even fit without hanging lower than the X member by a considerable amount, 2.75 is the largest you will be able to snake in front of the pan. 3" collectors to short 3" sections necking down to 2.75:
Car: 89 Formula
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I thought hedman sold a 3" ypipe seperately? I know hooker has one with the 2055's but I dont think they sell seperately and dont think it works with the 2460's.
3" single is perfect for a bolt on L98 or mild cammed setup up to 330whp or so. After that you should try 3.5" up to 400whp. 4" at 400 and higher.
Engine: 383 SBC
Either way it's better than the factory cast manifolds. According to Car Craft factory inner diameter of passenger manifold was 1.550"!
Car: 89 Formula
Not as much better as you would think... a 1 5/8ths primary is 1.625 outside diameter when you account for wall thickness there really isn't a whole lot there.
Engine: 383 SBC
Car: 89 Formula
Considerably is a matter of opinion...
That picture is deceptive if it's 3/4 of an inch that's a lot... And as everyone with a thirdgen knows having a good exhaust on one of these cars means sacrificing ground clearance somewhere there is really no way around it..
Car: 89 Iroc-z
Transmission: TH400
Hooker 2055's are at about 1.92". You can cut them open to 2.25" which will make alot of difference on a hotter motor that still needs shorties. Its a crappy ball/flange type collector so its not going to have the scavenging ability of a custom collector that you see on most longtubes and race designed setups. They should make midlengths for these cars with a good collector on them. Dyno Don's have the primary size, and support power, but I think they could be improved with a better shaped collector.
Car: 89 Formula
Car: 89 Iroc-z
Transmission: TH400
If you have any fab skills, making your own headers or turbo manifolds makes sense. If you have to make a manifold, might as well set it up for turbo and do a budget setup
Car: 89 Formula
Yea i've been planning on that for a while.. I actually have been sitting on a bbs manifold for a while but lack the funds to even get my car back on the street right now let alone buy a turbo and associated parts
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
