differant exost systems
What are the differences in exohst systems? What benefits do/or don't a y pipe give a built 350? And what makes putting true duels on a third gen so hard? I was looking at the under body and it appears to have enough room on both sides of the car to put duels from header back without running on only one side. On that note if a y pipe is beneficial can I just make a pipe to connect left and right pipes strait across? I've heard its just to equalize the exohst pressure or something like that is this true?
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: differant exost systems
Search button would solve your questions. And spell check.
Car: 87 iroc
Engine: mostly stock 5.7
Transmission: jasper stage 2 700r4
Axle/Gears: stock
just run off manifold/headers 2.5" into single 3" y pipe....single 3" y and intermediate can handle up to 525 horse...math has been done a long time ago by many others...look at subarus....duals are a pain in the a"" and cost decent money or ground clearance unless your a mastermind like the guy with the c4 irs....if you want loud go slp loudmouth one or two....
Car: 1989 Trans Am GTA
Transmission: M28 T56
https://www.thirdgen.org/forums/exha...aust-what.html
9192camaro
16
Feb 3, 2019 12:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
