using hose for the cat. converter injection tube.
Old Aug 24, 2011 | 09:47 AM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Hey guys I was wondering if instead of using the metal pipe that connects the catalytic converter to the air diverter valve if I could use a rubber hose instead. Would the hose survive or just get burned up from the heat? I have a new cat. converter with me and it has a stub for the metal pipe to connect to but they are the same size and I don't know how to make them fit..
Old Aug 24, 2011 | 02:30 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: using hose for the cat. converter injection tube.
How much is left of your original tube? If it's only been cut down by the cat, there's a kit with a high temp rubber hose and some clamps that most parts stores have, advance auto does for sure. I dont remember the brand though. It's just called a catalytic converter hookup kit, something like that.
You could also probably find everything you need at a hardware store (lowes in my case). On my car, the metal tube had been cut off up by the firewall when a previous owner removed the cat. I replaced several feet of missing line with some copper plumbing tube (something like 1/2 inch I think, whatever was closest to the original, it bends easily to shape) and some appropriately sized couplers/adapters when I put a cat in. Soldered it together like you would any plumbing copper pipes.
Old Aug 24, 2011 | 02:37 PM
Sparkytfl's Avatar
Found a picture, I know I've seen that exact brand one at Advance.
Old Aug 24, 2011 | 03:52 PM
0pyders's Avatar
Oh great idea I still have the whole metal tube.
You've been good help sparky, thanks.
Hotrodboba400
Dec 10, 2019 07:07 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
89fast5oh
Sep 8, 2015 09:55 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
