header/y-pipe question
Old Aug 25, 2011 | 01:59 AM
svandorst's Avatar
Car: 1992 Camaro RS
Engine: L98 5.7 350
I've got the factory dual-cat setup on my camaro, and I'd like to add some aftermarket headers to my car. I know of some y-pipes that are made for the dual-cat setup but they're serious bank..I'm on a bit of a budget and was just curious of what my options are?
If I need to fork over some dough to get a good flowing y-pipe then I guess I better start collecting my cans now lol.
Old Aug 25, 2011 | 07:36 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: header/y-pipe question
yup, save your money and a nice get stainless setup. In the long run you'll be glad you did!
Old Aug 25, 2011 | 01:42 PM
svandorst's Avatar
Car: 1992 Camaro RS
Engine: L98 5.7 350
Haha alright then cool, I guess I'll just do that then. Can anyone recommend some good headers with the air tube that are fairly well priced as well?
Old Aug 25, 2011 | 09:22 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
You will have to cut the ends off of your stock ypipe close to where they bolt up to the stock exhaust manifolds and either have a shop fabricate the new ends for you to bolt up to your headers or buy the ypipe that matches from the same header manufacturer.
Old Aug 25, 2011 | 10:12 PM
svandorst's Avatar
Car: 1992 Camaro RS
Engine: L98 5.7 350
Ok for example I go with the method where I re-use my stock piping and get them modified, wouldn't that defeat the purpose of the headers? Or is the stock piping on a dual-cat car have a decent enough diameter to allow good flow?
Old Aug 25, 2011 | 10:30 PM
ninetyone's Avatar
Axle/Gears: 3:42
Your fine if you have the dual ypipe (N10)option. Comparable to a 3" single pipe. The dual ypipe added something like 10hp over the single. What i did was install the headers myself and had the stock dual ypipe modified. Cost me $92 to have the welding done.
Old Aug 25, 2011 | 10:32 PM
svandorst's Avatar
Car: 1992 Camaro RS
Engine: L98 5.7 350
Modified how so? To fit the 3" collector on the headers? If so then $100 ain't too bad. Good to know that the dual-cat piping was good for 10hp over the single cat cars
And yeah I believe there's only one way the dual-cat car pipes work, 2 seperate pipes come down off of the collectors, both go into 2 seperate cats and then after the cats Y into the intermediate pipe correct?
I refuse to call the piping after the headers y pipes because no where in the piping does it y LOL
Old Aug 25, 2011 | 10:41 PM
ninetyone's Avatar
Axle/Gears: 3:42
[QUOTE=svandorst;5020844]Modified how so? To fit the 3" collector on the headers? If so then $100 ain't too bad. Good to know that the dual-cat piping was good for 10hp over the single cat cars [/QUOT
If you choose to keep the dual ypipe setup, it will be a lot easier for you to just cut your dual ypipes off at about 6 inches from where they connect to the exhaust manifolds, remove your exhaust manifolds, install your headers, drive to the shop (don't get a ticket for noise) and then have a shop fabricate the rest for you
Old Aug 25, 2011 | 10:46 PM
svandorst's Avatar
Car: 1992 Camaro RS
Engine: L98 5.7 350
Gotcha, cool well I appreciate your input on my little dilemma here haha. Puts my mind a bit more at ease about the whole thing when the time comes to put some headers in!
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
