Flowmaster Haters???
Old Feb 1, 2012 | 06:19 PM
  #101
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Flowmaster Haters???
Originally Posted by Camaro305SB
But, again, I have an LG4 so what do I know....
Old Feb 1, 2012 | 06:43 PM
  #102
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
I got flowmaster on my black car and magnaflow on my white one both with cats and 3" pipe and i love the way they both sound
magnaflow has a deeper sound to it.
Old Feb 1, 2012 | 09:14 PM
  #103
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Originally Posted by ninetyone
I think there was like a 20ft/lb torque and hp difference in the lower rpms. The Borla xs and the Flowtech Warlock made the most power compared to all the rest in that test.
Hmm.... Well here it is again.
Old Feb 1, 2012 | 09:58 PM
  #104
Ronnie Brennan's Avatar
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
I absolutely love my Super 44 Flowmaster's!!! My exhaust is "TRUE" Dual. Driver side header then straight back to the muffler which is located right under back seat with tail pipe curling just behind axle down and outwards so exhaust pushes out just behind the tire. Passenger side is the same way. No Cross over pipes, no cats no nothing.. Just 2.5" straight pipes to the mufflers! I dont splat at WOT but it does give off a light whistle though and makes it sound like I have a turbo haha.. I get asked that a lot.
Old Jan 22, 2015 | 10:51 AM
  #105
RSValor91's Avatar
Car: Maros: 89 Z28 & 91 RS
Engine: 350 TBI & 305 TBI OEM
I just bought a Thrush Welded, just one question: did you put a Cat First? I gonna put streight Pipe and Thrush at the end will this work? sorry for my english!!!
Old Jan 22, 2015 | 11:35 AM
  #106
Bigfoottpi11's Avatar
That will be very very loud with no cat
Old Jan 22, 2015 | 04:02 PM
  #107
Fireblood83's Avatar
Car: 82 Trans Am
Engine: 305 ci V8 4-bbl
Transmission: TH200C
Axle/Gears: 10 Bolt/3.23 posi
I wouldn't want them on any thirdgen. I personally like the factory sound. They are not supposed to sound like a late 60's or early 70's Muscle Car but as a 80's performance sports coupe. The factory tail pipes have a nice deep rumble and hide nicely under the rear bumper and you barely see them. I went for the Dynomax Super Turbo for a similar factory like sound and I like them compared to the Walker Quiet-Flow it had as a replacement. I would also go for Magnaflow but again with 2.5'' factory style tail pipes. I think Flowmaster sounds better with true dual exhaust cars and great on Mopars.
Factory exhaust system without cat.
Old Jan 25, 2015 | 08:55 PM
  #108
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Here's a reason some don't like the 80 Series Flowmaster and others do. When they are rated sound wise , close to the racing mufflers you know you can hear it inside and out.
Old Jan 25, 2015 | 09:58 PM
  #109
Old thread; didn't feel like contributing before, but now I will.
I bought a Blowmaster back in maybe the 93-4-5 range. Seemed like a good idea at the muffler shop after the stocker rusted out and fell off.
End result was, I. COULD. NOT. STAND. IT. It was like dragging an empty 55-gallon drum around behind me on a 20' chain everywhere I went. It got SO OLD SO FAST, I think it was no more than about 3 days, I was looking for ways to get rid of it.
Couldn't care less about "more power"; that's all well and good, but sometimes, what you gotta give up to get it, renders your car into a giant bucket of zoo dirt instead of the object of your dreams. (especially when no member of the opposite sex will get within a half mile of it) Gotta be more ... open-minded and balanced .... than just, some kinda "max power" dyno number.
Bought a Dynomax and put it on before all the paint was burned off of the Slowmaster. Gave the FM away to one of my littlest half-brother's street-stroke friends who hadn't accumulated the experience to know better yet. Great kid, really liked him, wouldn'ta took his money for it. I don't think it lasted a whole month on his car either.
Old Jan 26, 2015 | 02:09 AM
  #110
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
YEAH!!!!
Old Jan 26, 2015 | 02:31 AM
  #111
Phenom-1's Avatar
Engine: 5.7 TPI
For me, the way I see it, It all depends on the car (Year / SubModel / Engine ) And what look and Feel you want it to have... I think it can go either way. Stock or Aftermarket Exhaust depending on what you want to do.
My personal view as I see/feel them is Example: A Stock 1982 Z28 or Trans Am all original never modified, I'd lean towards keeping the original restricted exhaust because I like the throaty old fashioned sound.
But If I wanted to make it louder just for kicks, I'd also want to retain the option to always be able to put it back to stock without much If ANY welding required, because it's a very pristine all original car, so I'd get the 80s Series Flowmaster Catback system and clamp it on and take off the original setup in 1 piece and set it to the side in the garage until I feel like putting it back on.
If you don't ever want to be able to put the car back to original and this is definitely going to be some extensive aftermarket modification project built to stay that way and never look back, then obviously you can afford to sawzall the stock exhaust, and weld in some new extravagant custom built exhaust with dual cats, x-pipes, dumps, Etc.
My '92 5.7 has the complete 80s series 3" Catback setup with tips and all. Still has the stock Dual cats.
That's the way I bought it and I'd never change any of that because I think it's perfect and the car is 98% original so it's staying that way with the biggest mod being that Flowmaster.
I've always wanted a Blue '92 RS 5.0 T-top 25th Anniversary because my neighbors had one all original stock when I was 14.
I'll want it to be exactly the same, it had stock exhaust. So if I find one with a modified exhaust I'd take that off and find a stock setup.
In my view, the majority of Formula, Trans Am, Z28s SS IROC should have an aftermarket exhaust system like the Flow's 3" 80s series because they are the performance line and model of the F-body so they should be a little louder than the 3.1 5.0 RS and base firebird's sound with the stock mufflers.
Old Jan 26, 2015 | 09:27 AM
  #112
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Ive had several different aftermarket exhaust systems.Liked em all,especially BORLA. Now I run Flowmaster and no cat and it makes my lil 305 sound like a beast.I like it.
Old Jan 26, 2015 | 10:08 AM
  #113
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have never liked the sound of flowmaster on any motor domestic or import. Too much drone and it sounds too close to straight pipes which I dont enjoy.
Borla, magnaflow and OBX are some of the better sounding exhausts I have heard on these cars.
Old Jan 26, 2015 | 06:55 PM
  #114
Engine: TBI,5.0
Like I have mentioned in threads before I like the Hooker Aero Chamber.
If I were to go with anything other than the Flowmaster it would be that.
It IMO does have to go with the car and what your aiming for as to looks = sound.
Of course each muffler sounds different on different cars.
That goes for any muffler on any car.
Old Jan 26, 2015 | 07:59 PM
  #115
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I have flow masters on my 67 Camaro. When I first bought that car, it was my DD. I was living in Oklahoma at the time so I didn't really need to deal with Salt or the like so I wasn't worried about driving it in the winter. I did however, drive 12 miles to work one way, every day (@ $1.01 a gallon, who cared!!) and the sound (80 series) was horrible. I loved how it sounded when it roared, when I mashed the pedal to go somewhere. I LOVED it. But driving to the gas station, driving home, driving to work, just cruising at 65 on the freeway home became a chore. I could not stand it after about 6 months.
If it wasn't a DD and I NEVER had to drive the car more than 10 miles with Flowmasters on? Yeah, I'd put them on. Otherwise, never again.
On my firebird I am on my third Muffler. The first was a stock turbo muffler that sounded ok. I then swiched to the Aerochmaber and OMFG!!! that sound is so awesome. Cool at idle and cruise but tore it up when you got on it!
When that rusted out I went with a 3" Magnaflow Catback and this is, I'd say one notch down from the Aerochamber. My wife likes it much better though because now we don't have to strain to talk to each other in the car on the way to a meet or cruise. But man can she roar when I open the throttle. The magnaflow is more, understated than either of the other two, a little more mellow, and that's ok. It took me a while, but it really grew on me. When the Magnaflow goes, I'm probably going back to the Aerochamber.
Also, the Aerochamber, from everything I've read, out-flows both the Flowmaster and Magnaflow mufflers.
Old Jan 26, 2015 | 09:58 PM
  #116
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
I had a flowmaster until it rusted out at almost every seam on it. I run a Magnaflow bullet muffler now. Stainless FTW
Old Nov 28, 2017 | 08:09 PM
  #117
fullsize fun's Avatar
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
I've never understood why people want to install a barn door in the exhaust flow....notice flowmasters boxes and advertisements never talk about performance, just sound.
Old Nov 28, 2017 | 09:35 PM
  #118
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
I always liked my Flowmaster.. it was loud and I had no cat. The neighbors and my parents hated it..
I was never into the Fox body Mustangs with Flowmasters and that, “Woo Wooo” sound.. Camaros always sounded more muscle to me.. more growl
I love my Magnaflow because it’s present at high RPM and sounds almost stock at idle.. just a little extra growl at idle.. people get shocked when you rev it..
I always liked the SLP Exhaust on the Camaro SS cars in the 90s.. not sure if that’s what TTop350 was talking about, but I like that SLP..
The Flowmaster did get old on highway trips.. especially without a cat
Old Nov 28, 2017 | 09:51 PM
  #119
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
With my stock LB9, it's all about sound. A few more or less hp isn't going to make or break me but filling my ear with awesome tones makes a big difference. And stock LB9s can sound really good.
Old Dec 5, 2017 | 02:50 PM
  #120
Abubaca's Avatar
To answer the question, I don't like the Flowmaster drone. i actually removed mine before really getting on the boards and realizing many people felt the same way.
But....it's opinion as to what sounds best. As for performance, I don't think any crossflow muffler performs as well and any straight through muffler.
FWIW...I'm a fan of the Hooker.
And to anybody that does or does NOT buy a certain system because of the exhaust tips...REALLY!?!?!?!? I mean....REALLY!?!?!?!??
Old Dec 6, 2017 | 11:16 AM
  #121
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
I absolutely love my flowmaster.......just thinking about it makes me want to drive the car randomly....
I've had the 80 series American Thunder catback since 1999.....replaced once.
Maybe it's not the best for performance, but the car will run 117 mph in the quarter.
Another muffler might get me another mph or 2. But the sound is more important to me.
I get compliments all the time.
Old Dec 6, 2017 | 11:41 AM
  #122
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
From the time I was 16 in the mid ninties everything I ever owned had to have flowmaster. I've had built small blocks running through single chamber flowmaster, delta series, and have a flowmaster on my GTA currently. I'm done and over them. Soon as funds let me I'm gonna have all new exhaust and leaning towards borla or magnaflow. The drone has gotten old. After some research I will decide which way to go but I'm looking for mellow until I stand on it.
Old Dec 6, 2017 | 09:24 PM
  #123
Engine: 350 TPI L98
Transmission: WC T5
Have you checked out the SLP Loudmouth 2?
Old Dec 6, 2017 | 09:29 PM
  #124
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Actually I have watched about a dozen videos since I previously posted and I am very interested. Would love to hear a set up close. All the sound clips I've heard they sound mellow from idle to medium throttle and sound sinister when they hammer down on them. Got to find someone local with a set on a small block.
Old Dec 8, 2017 | 03:52 PM
  #125
turboguard's Avatar
Car: 1985 Pontiac Firebird Trans Am
Engine: 305 LG4
Transmission: 700R4 Automagic
Axle/Gears: No clue
I love the sound of Flowmasters, and I actually enjoy the road drone, but to each his own.
When you start insulting people who prefer one brand over another it really makes you look like a child.
Old Dec 8, 2017 | 04:13 PM
  #126
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Who insulted anyone? I don't see that anywhere in this thread.
Old Dec 9, 2017 | 08:16 PM
  #127
Engine: LB9 305
No one was insulted, I just said I didnt understand why people wanted to go Slower...
Veaceonee
Sep 29, 2016 08:15 PM
92camaro350cci
Oct 14, 2015 09:29 AM
Night rider327
Oct 9, 2015 09:25 AM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
89fast5oh
Sep 8, 2015 09:55 AM
