Front two driver side header bolts. How to attach bracket.
Old Jan 14, 2012 | 10:37 AM
ironreaper87's Avatar
Car: 1987 IROC Z28 Camaro
Engine: HSR L98
Axle/Gears: stock
Well its Saturday and I planned on putting the headers on.
87 IROC, Problem.
The front two bolts for the driver side header need to hold on the A/C pump / accessory bracket of course.
Could anyone be so kind to explain how they accomplished this or show pictures?
I've made a spacer for the first bolt that is the size of the manifold, but the second one.
There is no space between the primary tube and hole to put the original bolt back in.
Thank you for the help.
Old Jan 29, 2012 | 12:37 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Front two driver side header bolts. How to attach bracket.
this is exactly why i hate headers,they FORCE you into fabrication,like it or not.this is also why i left the manifolds on ,they fit and headers DO NOT
Old Jan 29, 2012 | 07:30 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
To perform this install on my 87 required cutting the a/c bracket. The headers actually came with a template showing the area that needed to be removed. Only the front header bolt will be holding the bracket.
Steve
Old Jan 30, 2012 | 12:34 PM
Engine: HSR L98
Axle/Gears: stock
Steve
Made a spacer and welded an addition to the A/C bracket that extends back to the third header bolt. Will post pictures in a little while.
Old Jan 31, 2012 | 02:38 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
87 IROC, Problem.
not the best pic,but to the far left you may see my bracket i made,its a long bolt and a spacer in the middle with 2 washers on each end
Attached Thumbnails Front two driver side header bolts.  How to attach bracket.-headers.jpg
transaero
Aug 31, 2015 01:14 AM
Street Lethal
Aug 14, 2015 08:25 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
