Dual Cat Y Pipe
Old Feb 26, 2012 | 10:43 PM
Guest
Guest
Posts: n/a
Dual Cat Y Pipe
Hey guys, what would you recommend for a y pipe into two cats? Yes I am keeping the cats. Should I go to one cat and if so, whats the best way to go about that? Or would I be able to get a one cat Y pipe to fit in to the two set up? Easiest way would be to just get a two cat y pipe, but where would I find one?
I am sixteen and ignorant on this so I have to be educated any way I can.
Old Feb 26, 2012 | 10:50 PM
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
Re: Dual Cat Y Pipe
are you getting headers? what are your plans with the car? do you have anything else done with the car?
if its all stock, your money would be best spent on a catback exhaust, the hooker aerochamber i believe is the cheapest. changing just y pipe on stock manifolds wouldnt do much for you and probably wouldnt hear a difference either.
Old Feb 27, 2012 | 05:39 PM
hatemail72's Avatar
Car: this and Dodge Dakota Quad
Engine: 383 tbi
Transmission: 700 R4
Axle/Gears: 3-73
Re: Dual Cat Y Pipe
The y pipe is it the same for the 2 styles of exhaust manifolds
My car has the 305 with the injector tubes. where as the 350 doesnt have any exhaust injector tubes will the same y pipe work on both applications
Old Feb 27, 2012 | 06:44 PM
Guest
Guest
Posts: n/a
Re: Dual Cat Y Pipe
Yes I am putting on headers and a cat back. The Headers wont fit the stock Y and so I am wondering where I will find a Y to fit the dual cats.
LC2 TECH
South West Region
50
Jun 30, 2016 10:47 PM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Eric-86sc
Sep 22, 2015 08:25 PM
Camaro_383
Sep 11, 2015 11:28 PM
