Newbie exhaust question
Old Feb 29, 2012 | 02:20 AM
RFR's Avatar
RFR
Just for the record, I did a search first.
I may have the opportunity to pick up a clean RS, with one problem...........
a cracked exhaust manifold.
Anyone care to share what is involved with removal and replacement of a stock manifold?
Car has TPI if that makes a difference.
Thanks.
Old Mar 4, 2012 | 04:26 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Newbie exhaust question
Lotsa' elbow grease, a case of penetrating oil, a propane torch. Oh! Some beer wont hurt, either.
Old Mar 4, 2012 | 08:21 PM
smokin berlinet's Avatar
Car: 1984 Chevy Camaro Berlinetta
Engine: 305sbc...soon...406 SBC
BEER ALWAYS HELPS!!! use plenty of penetrating oil... ease the hardware..Use a breaker bar and apply even pressure rather than beat a short wrench with a hammer....Don't let them twist and break. Use a torch if needed. And have a good supply of qaulity beer on hand.....
Old Mar 4, 2012 | 09:36 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
don't waste your time with wd40.use pb blaster or something simular.btw if i had to pull off a manifold id try to go ahead and install headers.
Old Mar 4, 2012 | 09:48 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
An RS with TPI? The guy mentioned that that engine didn't come stock in any RS Right?
Old Mar 4, 2012 | 09:56 PM
Car: 1992 Camaro RS
Use Liquid Wrench Penitrating oil. You can pick it up at just about any hardware store. Make sure the manifolds are cool or the oil is dry before starting the engine as it is flamable. You dont need to spend 50 bucks to get a pro braker bar. Just use any durable piece of piping (No not a broom stick or PVC pipe). I just went to a Lowes and bought a 3/4 X 34" steel pipe. Works just fine.
Old Mar 4, 2012 | 10:06 PM
BT85's Avatar
Car: 85 Camaro Z28
any beer other then bud light will do the trick... never drinking that again
Old Mar 9, 2012 | 08:57 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
I hit the bolts with the torch over and over again and they eventually came off.
Enjoy!
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
R3500
Aug 24, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
