2210 install ?'s
Old Feb 29, 2012 | 09:16 PM
92Z's Avatar
92Z
2210 install ?'s
From the hooker 2210 install PDF:
Your vehicle must be raised a minimum of 36 inches.
Is that true? Will these go in if not raised that high?
I don't know if i can get my car that high with a jack and jackstands.
The highest i've had my car was to remove the auto tranny. I had to "tip" it forward a little to get it to come out from under the car (to clear the bellhousing).
Just curious how you guys got the car that high.
Old Feb 29, 2012 | 09:42 PM
88gunmetalgta's Avatar
Re: 2210 install ?'s
I have really tall jackstands.
Yes, it has to be up in the air quite a ways.
you'll also have to unbolt the motor mount and lift the engine.
I also had to notch the passenger side A-arm mount, and weld in a patch panel.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
tricky1
Aug 23, 2015 01:17 PM
