Side Exhaust
Old Mar 24, 2012 | 07:41 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Side Exhaust
Dual 2.5" side exhaust with Moroso Tubular mufflers.
Old Mar 24, 2012 | 07:54 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Side Exhaust
Wow that is clean, I have the tube mufflers and my exhaust is in the drawing board stage. I was going to run mufflers like yours but keep going with tail pipes to exit out the back.
Old Mar 24, 2012 | 07:59 AM
wdigitog's Avatar
Re: Side Exhaust
Why? The added length of the tail exhaust is a power killer! I'm telling you, this set-up is killer! Try it.....added bonus: You won't drag your pipes anymore backing out of a steep driveway! lol!
I have two 2.5" pipes going out the side....your tail exit exhaust will have everything into one 3" pipe? That's my 5" of exhaust vs. your 3" exhaust!
Old Mar 24, 2012 | 08:07 AM
Edwardgp's Avatar
Engine: 454-350
Re: Side Exhaust
Might try that first it would not be to hard to change to the full length if I wanted to.
Old Mar 25, 2012 | 11:32 AM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
Re: Side Exhaust
dual 2.5 does not make a 5", there is not much difference from a dual 2.5 to a 3"
Old Mar 25, 2012 | 11:55 AM
tyler86z28's Avatar
Car: 1986 Camaro Z28
Engine: 355 4 bolt 4bbl
Transmission: T-5 manual
Axle/Gears: 3.73 posi.
Re: Side Exhaust
I had single side exit 3.5" on mine, but scraped on bumps due to car being lowered. I switched to 2.5" rear exit, and I swear I lost about 40 hp. Feels like the car can't breath now..lol
Old Mar 25, 2012 | 04:42 PM
Edwardgp's Avatar
Engine: 454-350
Re: Side Exhaust
That is something to think about for sure since I do not have the exhaust built yet. My mufflers have a 3" I.D. maybe I need to go 3" all the way, have to change pan bar though.
Old Mar 26, 2012 | 08:21 AM
wdigitog's Avatar
Re: Side Exhaust
Does your exhaust set-up include a y-pipe? Does your y-pipe feed a single 3" pipe to the rear?....I have a true dual 2.5"....ie: 4 cylinders feed a 2,5" pipe. If you have a single 3" pipe...then 8 cylinders feed a 3" pipe....you're forcing more exhaust into a smaller pipe! It's semantics.....this exhaust breathes better than a stock system.
Old Mar 26, 2012 | 10:21 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: Side Exhaust
Why wouldn't it be equal to a 5"?
Old Mar 26, 2012 | 11:42 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Side Exhaust
There is a nonlinear relationship between area and diameter of a circle. A circle 1 inch in diameter has several times the area of a circle 1/2 inch in diameter. For example, as far as internal cross sectional area goes, dual 2.5's are only slightly, slightly larger in area than a single 3.5. Beyond that, more smaller pipes have more internal surface area for turbulence and drag. A single pipe will have less surface area even if it's much larger.
Cross sectional area of a single 2.5 pipe: 4.91 square inches. Double that for two pipes, so 9.82 in^2.
Cross sectional area of single 3.0 inch pipe is 7.07 square inches dual is 14.14 square inches.
Cross sectional area of a single 3.5 pipe is 9.62 square inches.
Length should not, in and of itself, kill power. It will tune the exhaust for a lower power band. Ie, longer exhaust pipes may yeild better power in the 2000-5000 range, and a shorter pipe may yield better power in the 4000-8000 range.
Old Mar 26, 2012 | 06:12 PM
Edwardgp's Avatar
Engine: 454-350
Re: Side Exhaust
Oh my that is some info on exhaust.
Old Mar 26, 2012 | 06:48 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Side Exhaust
Originally Posted by Edwardgp
...... 3" all the way, have to change pan bar though.
A well designed & built (many manufacturers already built them) mandrel bent pipe can easily clear a stock PHB & PHB brace, so they don't need changing.
Old Mar 26, 2012 | 08:09 PM
Edwardgp's Avatar
Engine: 454-350
Re: Side Exhaust
Thanks for that info also, I know the exhaust guy here in town so I think I can get my bends from him for a price.
Old Mar 26, 2012 | 09:17 PM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Re: Side Exhaust
II was going to say it tucked up nice until i saw the last pic.
clean setup though! Hows the sound?
Old Mar 27, 2012 | 04:11 PM
83 Crossfire TA's Avatar
Re: Side Exhaust
Yea, I'd love to hear this setup...
Old Mar 27, 2012 | 04:16 PM
Re: Side Exhaust
Actually, it will. The longer the tube is the more restriction it is at the same diameter, add a few bends and it's a lot more restrictive. OTOH, as the exaust gets longer the restriction the same diameter tube presents goes down because the velocity (volume passed/time period) goes down both due to the restriction and because of cooling. Nutshell, the way it usually ends up working out is 2.5" mufflers and turndowns right after the header collectors are probably not more of a restriction than 3" all the way back, but swapping 2.5" for the tubing after the muffler(s) in that 3" will usually make little if any difference in restriction (though it will usually be significantly quieter)
Old Apr 6, 2012 | 08:17 AM
wdigitog's Avatar
Re: Side Exhaust
Here's a sound clip...
http://www.youtube.com/watch?v=cLZTN4QoeII
I had the traditional aftermarket thirdgen exhaust before ( Hookers ) and drove that around for about 4 years. When this was put in I could feel the same motor wake up. The throttle response was much quicker and the motor ran much smoother all the way through the power band. I did not notice any loss in low speed torque...in fact, the car launches in first much easier than before without any stumbling....I'm sure the shorter exhaust has affected the tune of the motor a bit...perhaps a bit richer? I have not touched the carb yet.
Old Apr 6, 2012 | 11:01 AM
duf6's Avatar
Car: '86 z-28 with true duals
Engine: carbed 350
Transmission: t5
Axle/Gears: 10 bolt 3.42 posi
Re: Side Exhaust
I think it would run leaner.
Old Apr 6, 2012 | 07:56 PM
wdigitog's Avatar
Re: Side Exhaust
Ok...that's probably why it runs better now....it was a bit rich before.
1992 Trans Am
May 10, 2023 07:19 PM
transaero
Aug 31, 2015 01:14 AM
db057
Aug 22, 2015 08:17 PM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
