Headers and Oil Pans for 383
Old Apr 18, 2012 | 07:09 PM
Hrock's Avatar
Got to pull the new engine again to change the Pan... The problem is What Pan would work ? Stock TPI motor Pan ? or some after market ? I need enough room to run a 383 motor and the 68476 hedman Headers. Can not search and find specific data on what leaves enough room to get a 2.5" or so cross over pipe.
1989 4 bolt Main ( single peice )
Scat crank and rod setup ( 3.75" stroke )
Hedman Shorty's meant to cross over exhaust at the oil pan.
No room at the Crossmember..
So I used a 5 quart truck pan for a windage tray setup used for a marine application which was reinforced with Skid rails and then poweder coated.
Looks Great.. Except I can not get any decent size cross over pipe to fit now.
Old Apr 25, 2012 | 11:17 AM
Hrock's Avatar
Re: Headers and Oil Pans for 383
Well Looks like a 93 and up LT1 Pan was the option..
Moroso 20185 - 20mm Hydraulic ORB Plug and a little manipulation on the pan itself and we are in business.
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
