Paint melted
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Paint melted
Ok so on my headman headers i decided to paint them nice an black to get rod of the rusty look but all of the sudden i drove the car around the city when i puled back into the driveway i noticed that the paint faded away what caused that i did use high heat engine enamel paint that with stood up to 700 degrees ???
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Paint melted
exhaust gets hotter than that. You need specific header paint.
Car: 84 trans am
Engine: 350 bored .020 over
Transmission: TH350 w/ stage 2 B&M shift kit
Axle/Gears: 9 bolt/3.27
Re: Paint melted
yeah my VHT paint lasted about an hour...I even baked it and everything.
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: Paint melted
i used grill paint on mine an what i didn't chip off putting them on is staying ok . i need to redo them whith them on the car . i skun the hell outta them putting them on .lol
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Paint melted
My vht ceramic header paint applied and baked on as per the instructions (both in oven and on car) has lasted 800 miles on some bad tunes with a turbo - it's pretty good stuff if applied correctly
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Paint melted
Engine enamel on headers = Fail
You need high heat header or bbq paint 2000º and even then the paint will come off. They have to go trough a baking process, noted in the instructions on specific high heat paints.
Engine: l98 tpi
Axle/Gears: 2.77
Re: Paint melted
heres my headers :
like i said i need to redo them but i think this paint is holding up for the parts i didn't scrap off ...
i'll redo them in this paint when i change the cam
like i said i need to redo them but i think this paint is holding up for the parts i didn't scrap off ...i'll redo them in this paint when i change the cam
Car: 92 Camaro RS
Engine: 355 L98 Carb
Transmission: WC T5
Axle/Gears: 3.73 Auburn Posi
Re: Paint melted
I used that same can of paint on mine but in black.. had to get the drivers side heated up almost red hot so I could angle the collector downwards some and the paint just flaked off once the acetylene torch hit it... guess I'll repaint that area and then see how it does once I fire up the car.. I'm thinking that I will probably have to heat cycle them a couple of times and then pull them off and repaint them again..
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
