NO 3" y-pipe for Hooker 2460? (custom $?)
Old May 29, 2012 | 12:50 AM
Austin19's Avatar
Car: 1985 Camaro Z28
Engine: 305 LG4
Axle/Gears: 3.08
I have seen this question asked a few times in the past and I just wanted to make sure it is still the case. I want to go from Hooker 2460 headers to Hooker 16823 aerochamber cat-back, and buy a y-pipe that will delete the cat. The Hooker 16767 goes down to 2.5" at the I-pipe connection, correct? Is this the only y-pipe that will join these two parts?
I would like to keep the whole system 3". If the above is correct, the only way to do this would be through a custom y-pipe. I have no idea how much these things cost, so does any one have an idea of the price of a custom y-pipe?
Old May 29, 2012 | 04:49 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: NO 3" y-pipe for Hooker 2460? (custom $?)
I found this on JEGS. It's a hooker Y-Pipe that fits the 2460's. It doesn't say if it's 3" or not, but a call to JEGS would solve that.
http://www.jegs.com/i/Hooker-Headers/520/16767/10002/-1
Old May 29, 2012 | 07:52 AM
ghost91's Avatar
Car: 1991 Camaro Z28
i posted something like this a little while ago asking the same question. thats the only they make for the 2460, and ive heard the quality of it isnt that good anyway, so custom y pipe mite be your only option. and it is a 3" to 2 1/2'' where the cat delete is.
Old May 29, 2012 | 08:37 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Probably why most everyone goes with the 2055's and if they don't want/need emissions, they just cut off the AIR tubes and weld them shut.
Old May 29, 2012 | 08:43 AM
ghost91's Avatar
that is what his other option is. they have a normal y pipe which is better quality than the cat delete one, but you can just weld in some extra pipe going to the intermediate pipe, if your running no cat
Old May 29, 2012 | 09:53 AM
Austin19's Avatar
Engine: 305 LG4
Axle/Gears: 3.08
Thanks for the replies guys. I almost wish I would have went for the 2055s instead, but I got a crazy deal on my 2460s.
I guess my question is now - how much should I expect to pay for a custom y-pipe?
Old May 29, 2012 | 09:55 AM
ghost91's Avatar
maybe 250...who knows. go to a couple shops and get estimates.
Old May 29, 2012 | 10:09 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Old May 29, 2012 | 12:35 PM
Austin19's Avatar
Engine: 305 LG4
Axle/Gears: 3.08
Just out of curiousity, would a 3" crush bend be better than the Hooker 16767 (mandrel bend, 2.5")?
Old May 29, 2012 | 01:32 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Probably not a lot of difference.
Mark.
Old May 29, 2012 | 04:38 PM
ghost91's Avatar
im not sure if dyno don uses the same flange type as the 2460s, but his y pipe is pretty affordable and ive heard nothing but good things about it. just may have fitment issues cuz there not his headers, but it could be worth a shot
Old May 29, 2012 | 06:03 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Mine would be a good start but if you use this one and cut it right where it goes down to
2 1/2" and put a 3" bend on it it would work better.
Old May 30, 2012 | 12:02 AM
Austin19's Avatar
Engine: 305 LG4
Axle/Gears: 3.08
Thanks for all the replies guys, even Don got in here to tell me not to buy his products! Great customer service right there.
I guess my question now is if it is worth it to go for the custom 3" work or just buy a 16767 y-pipe and install it myself? I know it isn't worth it now with my stock LG4, but I would like to make some more power out of this engine in the near future. How much HP would this system (good headers, y-pipe with a chokepoint of 2.5" where it meets the cat-back, and then a 3" cat back) be able to support, cfm wise? I know that probably depends on a variety of factors, but would this handle 300-350 horse without a doubt?
Old May 30, 2012 | 12:11 AM
Ozz1967's Avatar
Car: 1984 Trans Am
A 3" system with a 2.5" choke point, is only a 2.5" effective pipe. A 3" single flows only about 10-15cfm less than a true dual 2.5" (google it, should be close). It's definitely worth getting the 3" system...for a 350 or larger motor. For a stock or mild build 305, you probably won't see the gains out of it. Chevy High Performance did a build on a 305 that got 358hp. So that kind of power is doable, if you build it right. If you do a build with 300hp+ on a 305, you'll want the 3".
Austin19's Avatar
Engine: 305 LG4
Axle/Gears: 3.08
Thanks for the info Ozz. I think what I will go for is the 2.5 for now, and get custom work done to make it 3" when I have the money and more power.
Also, how much will this reduction down to 2.5 inches affect sound compared to a full 3" system?
Old May 30, 2012 | 12:12 AM
Ozz1967's Avatar
Car: 1984 Trans Am
It won't. That aerochamber you're looking at getting is a mean muffler. Sounds wicked under WOT and has a nice rumble at idle and when just cruising around.
Old May 30, 2012 | 12:16 AM
Austin19's Avatar
Engine: 305 LG4
Axle/Gears: 3.08
Thanks! Everything is solved. This is such a helpful website, I love it.
Old May 30, 2012 | 05:03 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I made a good flowing pipe using the Doug'd D901 y pipe for much cheaper than the hooker pipe. It bolts right up to the 2460's and all I had to do was cut off the 2.5 pipe, expanded the opening and weld in a 3 inch. worked great for a budy of mines 91 tbi car.
Old Jul 29, 2012 | 06:27 PM
blackjack12982's Avatar
I've got a few basic questions, I'm trying to get an idea of what I'm going to be facing when installing a set of 2460's. I just got a deal on a set with no Y-pipe. I'll probably end up using the Doug's Y-pipe, is there a recommended set of gasket's for these? Any tips from others that have done this install? The only smog equipment left of my 92 5.0 TBI are the heat risers, and these are non-AIR versions. I should mention I have access to a lift, if they go in easier from the bottom.
Thanks!
Old Jul 30, 2012 | 02:51 PM
Thanks!
Gasket type for me really depends on how flat or true the header flange is. If it's good and flat then some good fel-pro gaskets work fairly well. If they are slight off then the dead soft aluminums have worked well for me. For the collector gaskets I like to use the aluminum gaskets as they have never failed on me. It's always been a hit or miss with the metal/paper gaskets for me.
getting the 2460's in is pretty straight forward and easy once you get the old manifolds off. They'll drop right in from the top no problem.
Old Jul 30, 2012 | 03:25 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I much prefer the non-gasket style of the 2055's to any gasket style.
Old Aug 5, 2012 | 05:47 PM
kickass92z's Avatar
Car: 92 Z28/86 T/A/98 R/A T/A
Engine: 355,355,LS1
Transmission: T-56,700r4,T-56
Axle/Gears: 3:73,3:42,3:42
i WISH YOU WERE CLOSER, AND i WOULD MAKE YOU A CLEAN Y-PIPE FOR $100. I built mine, with a custom cross member, and a 4" out the back with a hooker aero-chamber. I have actually had a couple people tell me it sounds like a Ferrari. Don't know about that but, I really like the sound either way. As for the 3" crush bend vs. mandrel 2.5" Unless you have a crazy engine, the 2.5 would be plenty. Mine is really over kill, but I had to prove a point. Before I opened my own exhaust and fab shop I had guys laugh at me when I told them what I wanted under my car. One guy even call me an idiot. So to prove him wrong I built it. I will post up some pics soon. I plan on making some changes to the car and having the whole exhaust system ceramic coated.
Old Aug 5, 2012 | 05:52 PM
Dangit, I just moved here a couple of months ago from Ft Campbell, KY... If you could replicate a Y-pipe, I might be able to swing down.
Old Aug 5, 2012 | 08:51 PM
kickass92z's Avatar
Engine: 355,355,LS1
I could do one about any afternoon. Where are you at now? Just saw Ft. Knox? If so your only about 2 hrs from me..
Old Aug 5, 2012 | 09:20 PM
Yep, Knox for another 9-12 months or so. Let me get to that point, and I can get ahold of you when I'm ready. It'll be at least 2-3 months, unless I sell my other toy.
Old Aug 6, 2012 | 04:08 PM
kickass92z's Avatar
Engine: 355,355,LS1
Just shoot me a pm when you are ready, and we can set-up a weekend to come down and get it done.
Old Sep 16, 2012 | 01:19 AM
kauboy's Avatar
Car: 83 Z28 Crossfire
Just installed my 2460's with Hooker y pipe everything fit nice.Trying to post pics
Yeah, it's a 2 1/2" Y pipe.
Attached Thumbnails NO 3" y-pipe for Hooker 2460? (custom $?)-83-crossfire-033.jpg   NO 3" y-pipe for Hooker 2460? (custom $?)-83-crossfire-034.jpg   NO 3" y-pipe for Hooker 2460? (custom $?)-83-crossfire-035.jpg
Old Sep 16, 2012 | 01:28 AM
kauboy's Avatar
I also installed the off road cat eliminator that came with the Y pipe. Problem is that the Xcelerator 2 1/2" cat back exhaust muffler, when standing behind the car you can hear a definite difference in sound coming out of the tailpipes the right side is way louder!!!!
Old Sep 29, 2012 | 11:35 AM
Dyno Don's Avatar
I just redid the Y-pipe on a set of 2460 headers.
Changed it to 3" where it drops down to 2 1/2"
Attached Thumbnails NO 3" y-pipe for Hooker 2460? (custom $?)-dcp_1334.jpg   NO 3" y-pipe for Hooker 2460? (custom $?)-dcp_1335.jpg
Old Sep 29, 2012 | 04:41 PM
kickass92z's Avatar
Engine: 355,355,LS1
I will get a thread up soon of my exhaust. It is a custom y and 4 inch to a hooker aerochamber. Even built a trick tranny x-member....
Old Sep 30, 2012 | 11:14 AM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
That's what I did with my Hedman "Y" pipe. Worked out pretty well.
Mark.
Old Jul 2, 2017 | 11:28 AM
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
Those of you who cut off the bottleneck of the y-pipes, and welding in a 3 inch piece, did you cut before the y, and find a 3 inch "y" section, or did you just cut after the y, before it gets down to 2.5 inches?
Old Mar 24, 2020 | 12:42 PM
Tidan's Avatar
I'm curious about this too. I have the 2460's with the hooker 2.5" y pipe and need to join it to my existing 3" exhaust without restricting it down to 2.5.
Old Mar 25, 2020 | 01:35 AM
thirdchance's Avatar
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
Hey kauboy. How's your starter doing with the header heat running by it? Still good? I haven't put mine on yet.....
Old Mar 26, 2020 | 03:03 PM
potterc32's Avatar
I have a mini starter on my car with the y pipe pretty close, and haven't had any problems yet. it's been over 2 years now. and I just cut the y-pipe right at the "y" and welded on a 3"oval pipe. I cut the "y" as far back as I could without making the hole bigger than the Oval. I am very happy with the results!
Old Mar 26, 2020 | 05:45 PM
Tidan's Avatar
Any tips for ovalizing 3" exhaust to fit the 2.5" y-pipe collector?
Old Mar 27, 2020 | 12:56 PM
potterc32's Avatar
I purchased some oval pipe sections from summit. Worked great!
Old Mar 27, 2020 | 01:22 PM
Tidan's Avatar
Very cool! Thanks!
And it looks like it clears your subframe connectors too! Are those the UMI's?
Old Mar 28, 2020 | 08:18 AM
potterc32's Avatar
Yes they are! My old exhaust rested right against the small support of the subframe connectors. Always made obnoxious noises. Love my new exhaust!!
Old Mar 28, 2020 | 11:56 AM
Tidan's Avatar
Did you do oval all the way back or did you transition to round?
Old Mar 28, 2020 | 12:08 PM
potterc32's Avatar
I transitioned back to round right before the electric cut out. The cut out is right where the catalytic converter used to be.
Old May 1, 2020 | 09:29 PM
  #42
Tidan's Avatar
How close is the passenger side tire at full right-lock to the Ypipe bend for you guys?
I'm fabbing up a oval to 3" adapter and have concerns about how close my set up may come to the tire.
pontiacdog
Apr 18, 2014 04:11 PM
ghost91
Apr 21, 2012 06:29 PM
firebirdjones
Nov 8, 2005 07:43 PM
