Hooker headers 2460-1HKR/y-pipe question
Old Jun 28, 2012 | 09:07 PM
Stu's '85 IROC's Avatar
I am looking into buying a set of Hooker Headers part # 2460-1HKR for my '85 IROC with a TPI 305 in it. I am pretty sure they will not bolt to my factory y-pipe- right? Does anyone know where I can get one that will work cheap (if the factory one won't work)? Any advice will be appreciated. Thanks in advance.
Old Jun 28, 2012 | 09:15 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Hooker headers 2460-1HKR/y-pipe question
2460's don't' come with a Y-pipe, and nothing is pre-made, you need to have an exhaust shop fabricate a Y-pipe for you.
The 2055's DO come with a Y-pipe but are more expensive (because they are better, and they come with the Y.
Old Jun 28, 2012 | 10:30 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Well to be completely fair the 2460's are made with heavier gauge steel and are technically slightly superior. But the 2055's have that awesome y-pipe, even though one side necks it down pretty far. 2460's have more potential if you can build yourself a decent y-pipe. I thought Hooker sold a y-pipe for it separately, but it wasnt a very good one. The 2055 y-pipe is much, much better.
Old Jun 28, 2012 | 11:06 PM
Smaller inner diameter because of the heavier gauge steel. They flow less than the 2055s do.
Old Jun 29, 2012 | 01:47 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I believe this is the 2460 y-pipe:
http://www.summitracing.com/parts/HOK-16767HKR/
Old Jun 29, 2012 | 08:11 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
I have the 2055's and they fit pretty nice, but I do have to say the passenger side was a royal PITA. I managed to get it in without jacking the motor up. My main reason for choosing the 2055's was that in my state I need to pass emissions and the 2055's retains all of the smog equipment
Old Jun 30, 2012 | 06:26 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
I put a set of 2460s on my 87. I ordered the matching Y pipe. The problem I ran into was the Y pipe hit the subframe connectors. I had to take it to a muffler shop to get it modified. They cut the end off to shorten it and found something interesting. The inside of the Y pipe was about half the diameter it should be. This was caused by the manufacturer not building the collector correctly. If I had used the Y as supplied, I would have had a pretty bad restriction. The muffler shop cut the restricted area off and fixed the problem.
Steve
Old Jul 3, 2012 | 02:01 AM
Car: 1992 Camaro RS
Now that is interesting... Makes a lot of sense too.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
