question about Hooker 2055 headers
Old Jul 20, 2012 | 03:10 PM
SaxophoMan's Avatar
Car: 1992 Firebird
Engine: L03 305 TBI
Axle/Gears: 2.73 posi rear
Have done tons of research online (including summit racing) and looking through lots of threads on here, but still not totally sure:
Will Hooker 2055s fit on a 1992 firebird with a 305 TBI?
According to at least Summit Racing and Amazon: no
From what I'm getting from the posts on here: yes?
Just want to make sure it'll fit, since they seem to be the way to go instead of 2460's... based on recommendations I've read and the fact that there is no 3" y-pipe sold for the 2460's (and I want 3" all the way back).
If the 2055's do fit, did anyone find any complications when installing (i.e: such as anything in the way, spark plug wires, etc.)?
Any help is greatly appreciated!
Old Jul 20, 2012 | 03:13 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: question about Hooker 2055 headers
Thread dedicated to the 2055's. I have an 89 TBI with them. No problems.
https://www.thirdgen.org/forums/exha...055s-come.html
Old Jul 22, 2012 | 11:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The main issue you'll have, is dual cats and if you have an emissions test, visual or otherwise. Those headers and Y pipe weren't made for a dual cat set up and will fail an emissions visual if you take one of the cats out ot make it work.
Old Jul 22, 2012 | 05:43 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
uh...
TBI's didn't have dual cats.
Old Jul 22, 2012 | 07:16 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Originally Posted by Dyno Don
uh...
and now I know. Carbed guy here, I just knew some later years came with dual cats.
Old Jul 22, 2012 | 07:35 PM
SaxophoMan's Avatar
Car: 1992 Firebird
Engine: L03 305 TBI
So, since I have only a single cat I shouldn't have any problems with emissions (whether visual or exhaust gas contents)?
Old Jul 23, 2012 | 04:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
As long as the air tubes are hooked up, no.
Old Jul 23, 2012 | 08:55 AM
SaxophoMan's Avatar
Car: 1992 Firebird
Engine: L03 305 TBI
Thanks!
Old Jul 24, 2012 | 08:51 PM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
do make sure to pick up some 90° angled spark plug wires though. Straight spark plug wires will not fit with headers.
Old Jul 25, 2012 | 09:10 AM
SaxophoMan's Avatar
Car: 1992 Firebird
Engine: L03 305 TBI
What 90 deg. angled spark plug wires and spark plugs did you get, specifically? Do you have Hooker 2055's? I'm having a hard time finding something online that will definitely work.
Old Jul 25, 2012 | 11:52 AM
Engine: LO3
I picked up these myself:
http://www.summitracing.com/parts/MSD-5562/
I don´t have Hookers 2055´s but 2460´s instead.
Pretty much the same thing though. The spark plugs in the swirl port heads protrude in a 90° angle from the head. You´ll have the same issue with any kind of header you want to put on that engine.
Old Jul 25, 2012 | 12:06 PM
SaxophoMan's Avatar
Car: 1992 Firebird
Engine: L03 305 TBI
Thanks! Any recommended spark plugs to go with those wires?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
