02 simulater
Car: 91camaro
Axle/Gears: 373
02 simulater
I have a 91 305 with headders and I wanted to know if any one knows where I can find o2 eliminators or simulators I live in San Antonio tx
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 02 simulater
you running HHO ? Last edited by Tuned Performance; Jul 26, 2012 at 02:33 PM.
Car: 1987 IROC-Z
Re: 02 simulater
o2 sim is only for vehicles with oxygen sensors post catalyst, they provide feedback for catalyst efficiency and typically only read a steady .5 volts. Typically they are run on OBDII vehicles that remove the cats. On a TPI or any other fuel injection system, you need a primary o2 to monitor fuel adaptations, using an o2 sim in this position will not allow the vehicle to run properly.
Car: 91camaro
Axle/Gears: 373
Re: 02 simulater
Well right now I don't have my o2's or my cat and recently it started running more rich then usual what would be the easyest way to stop that without putting the cat back on
Engine: Lb9
Transmission: M20
Re: 02 simulater
no you dont need a cat but your oxygen sensor will not work properly if its just straight piped out and the sensor is close to the exhaust dump. I did mean Bung !
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Re: 02 simulater
Then you only have one o2 purple wire lead on the drivers side.
Engine: Lb9
Transmission: M20
Re: 02 simulater
yes, if your car still is running rich then switch to a heated o2s. The o2s should be able to reach 500-600 and be fully functional if you have a bung in the headers up high like the stock location was any lower you need to run a 3 or 4 wire heated sensor.
Engine: Lb9
Transmission: M20
Re: 02 simulater
go have a bung welded in or buy a reducer with a bung installed and run a 25312179 (AFS-74)
http://www.jegs.com/p/Hedman/Hedman-...esc1%7C0&Nty=0
Engine: Lb9
Transmission: M20
Re: 02 simulater
it would be best up higher but might not get hot enough so you may need to run a heated o2s so it will work correctly.
Engine: Lb9
Transmission: M20
Re: 02 simulater
might not unless you have a laser temp gun quit guessing.
Car: 91camaro
Axle/Gears: 373
Re: 02 simulater
Kool and those heated o2s do I have too special oder them or could I find them in a regular auto parts store
Engine: Lb9
Transmission: M20
Re: 02 simulater
I have no idea what your auto parts inventory is. You can always contact jims performance .com for a sensor and pigtail.
http://www.jimsperformance.com/carty.html
Car: '91 TA vert
Engine: turboLSx
Re: 02 simulater
Just pick up an o2 sensor for a '95 MPFI blazer. It's heated and uses the standard weatherpack connector. Easy.
