Large single pipe or two smaller pipes?
Old Aug 1, 2012 | 03:18 PM
Guest
Guest
Posts: n/a
I have a 1992 Camaro 350 with the dual cat/y pipe set up. It would be easier due to aftermarket part availability to go to a standard y pipe set up? How big would I need a standard y pipe to be to outflow my current, stock set up with the 2, 2 1/2" pipes? Or should I just try to have some one custom fabricate two 3" pipes into a 3" cat back?
Old Aug 1, 2012 | 09:29 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Large single pipe or two smaller pipes?
Doug thorely and hooker both make a nice y-pipe setup. 2.5" y-pipe is all you need. Run that to a 3" or 3.5" collector and straight back. Single pipe is perfectly fine. Just remember the larger the diameter the larger the cost of cat, mufflers, resonators ect...
Just about any aftermarket Y-pipe will outflow your current.
PurelyPMD
May 5, 2016 04:57 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Camaro_383
Sep 11, 2015 11:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
