Dyno Don vs. 2055 - Coatings & Corrosion
Old Aug 25, 2012 | 09:49 PM
syoung_2000's Avatar
Car: 1991 Firebird Formula
Transmission: 700R4 to WC T5 swap
Axle/Gears: 2.73 drum to 3.73 PBR swap
Hey Everyone!
I'll be buying some headers ASAP. I have a dilemma.
I want to install them once and be done, without corrosion issues. (I'm talking relatively short time, I know nothing lasts forever.)
Dyno Don's - Seems like the go to guy. The only thing that bothers me is no coating on the inside of headers or Y-pipe. I'd want to get his finish blasted off and "Jet-Hotted", for the sole purpose of coating the inside. This would bring me up to well over $1000 total.
Hooker 2055 - I would have A.I.R. welded and send out to get all parts "Jet-Hotted" This may end up a little cheaper in total.
Questions:
Are metals on both brands equal?
How long would Don't last without inside coating?
Why would you & what is involved in test fitting the y-pipe before getting a coating put on them? I don't understand how it works?
If anyone's had Dyno Don's for a while without the inside coated, I'd like to hear how they hold up & if most of you get your Y-pipe coated.
Old Aug 26, 2012 | 01:56 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Dyno Don vs. 2055 - Coatings & Corrosion
Originally Posted by syoung_2000
Hey Everyone!
Questions:
The tubing that Don uses will not rust.
Old Aug 26, 2012 | 02:08 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Are metals on both brands equal? - Ask Don
How long would Don't last without inside coating? - Ask Don....My Edelbrock's lasted 15 years and them I had the stripped and coated. Now saving up for a set from Don.
Why would you & what is involved in test fitting the y-pipe before getting a coating put on them? I don't understand how it works? - To ensure clearance and make sure nothing touches/hits. Ask Don
If anyone's had Dyno Don's for a while without the inside coated, I'd like to hear how they hold up & if most of you get your Y-pipe coated. - Ask the people in Don's Thread (do a search).
Old Aug 27, 2012 | 01:57 AM
I sent Don a PM on this stuff as The Project suggested. I've searched but perhaps missed it.
Old Aug 28, 2012 | 04:19 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Dyno Don just said in a thread about his headers that he can now get the inside coated for a little extra. Ask him about it.
Old Aug 29, 2012 | 08:40 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've been running the same uncoated steel headers on my IROC since I installed them back in 99 or 2000. The insides are exactly as they were when I took them out of the box, and I sprayed some fairly useless ceramic header paint on the exterior. Other than a little bit of very minor surface rust, they're still fine. I can't possibly imagine that having Don's headers with an uncoated interior will be a problem from a longevity standpoint.
Old Aug 31, 2012 | 09:07 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Headers I have seen only rust significantly on the outside. Oxygen is required for rust, and there is not a lot left after combustion. The exhaust system usually rusts out from the mufflers back, where air (oxygen) can get in from the tailpipe. Regarding getting your headers coated internally, too, it is not for longevity, it is for "double down" thermal insulation.
TA
Old Sep 1, 2012 | 08:46 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
TA
Well said. When coated outside and INSIDE its just more effective. Keeps the heat IN the exh. a little more.
Old Sep 4, 2012 | 12:36 AM
Thanks for the advice. I'm gonna pay him to do the inside as well.
Couldn't hurt...
MustangBeater20
Oct 29, 2022 09:20 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
Infested
May 22, 2018 11:56 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
