body panel exhaust
Old Aug 26, 2012 | 12:31 AM
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
body panel exhaust
ok ive been thinkin about doing a custom exhaust on my firebird where the end comes out of the body panel behind the front doors is it possible or has anyone done it to there firebird if so post pics plz i want it like the pic below but behind my door in the body panel
Old Aug 26, 2012 | 09:51 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: body panel exhaust
almost anything is possible if your pockets are deep enough . your idea , practical ? no . benifit ? none . cost ? more than car . just take a look under your car and see . other than looking "COOL" why ? good luck .
Old Aug 26, 2012 | 02:03 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
A few guys have run the exhaust to exit below the gfx just before the rear wheel.
Personally, I like the dual tips out back.
Old Aug 26, 2012 | 08:04 PM
Engine: sbc 350
the reason I'm asking is cause I can get the tubing bent for free but idk if I'm all for currjng holes in my car especially if its gonna look dumb thimk I'll just have then come out under the body before the wheels
Old Aug 26, 2012 | 08:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
look under the car. there is no way to install exhaust like that on this car without cutting up everything, Aside from there not being anyplace to put a muffler before that point.
The rear control arms mounting points to the body are right there, they are hard points of the car, parts of the "frame" and there is no way to get a pipe there.
only way to do something like that would be in the rear, behind the tires, out the quarter panel, but you would probably loose the spare tire in the process.
its just not practical on this car.
Old Aug 27, 2012 | 09:21 PM
Engine: sbc 350
I don't have a spare tire and I'm not putting a muffler on the car I'm running two pipes straight down from headers and gonna run them out before the rear tires under the body
Old Aug 27, 2012 | 09:53 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I've seen then run out just under, but never through. You'd pretty much hafta go up through the floor to go out the side. Then build a new floor section over the pipe inside.
But I have seen these, including one with a muffler, for those who want a muffler & even mine has a bullet muffler just before the pipe goes up & over the axle so there are different ways to have a muffler before a side exit exhaust on a 3rd gen.
Attached Thumbnails body panel exhaust-84-camaro-exhaust-023.jpg   body panel exhaust-p1070701.jpg   body panel exhaust-standard.jpg
Old Aug 28, 2012 | 12:48 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
The side exit is not too bad, but through the body is a bad idea. I have seen some trucks like that and lever liked it one bit. I mean why cut holes in a vehicle?
Old Aug 28, 2012 | 01:22 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
How about some nascar boom tubes. Check out this thread.
https://www.thirdgen.org/forums/exha...st-plenty.html
Old Aug 29, 2012 | 08:43 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Here's a pic of an IROC I saw at Carlisle back in 2007. He modified the ground effects a bit, and ran the exhaust through it:
Old Aug 29, 2012 | 08:49 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
I think this is your best option.
Old Sep 10, 2012 | 03:18 PM
Engine: sbc 350
ya im gonna rub it under the body out before the rear wheels ill post pics when done having issues with the engine right now so trying to deal with that
Old Sep 10, 2012 | 06:14 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
With the under body and fact the car sits low, the only way to run it on anything used on the street is going to require cutting and fabrication. I've seen it done before - if done right it is a quirky & interesting detail, if not, it becomes a nightmare.
Old Sep 11, 2012 | 07:40 AM
Engine: sbc 350
ya I kno it'll have to wait for now tho gotta figure what's wrong with the engine I just rebuild it nd went to turn it over and nother happen
Old Sep 11, 2012 | 08:47 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
I see more drag cars run them out the front of the GFX and front fenders rather than than the rear. Its just not practical.
Old Sep 11, 2012 | 11:28 AM
makingPAIN's Avatar
Car: 1985 firebird
Engine: 350 .40 over
Transmission: 5 speed borg(NWC), ram clutch
Axle/Gears: ROTATING MERCURY DRIVE.
hey check out this months hot rod a guy has a bad *** camaro with side panel exhaust
Old Sep 11, 2012 | 01:13 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Two examples:
73 Firebird:
He pretty much backhalved the rear of his car to get room for it:
"Free tubing" is like saying you got a free rod bearing to fix your knocking sbc. It's a drop in the bucket compared to what it takes.
I strongly suggest you run mufflers. The no mufflers on a stock engine thing sounds awful and really perpetuates the stereotypes of inconsiderate, trashy thirdgen owners regardless of how wonderful of a person you may be. The 73 above is very loud and he went through the trouble of using THREE mufflers to keep it quiet.
It isn't cool when the entire town is annoyed at how loud your car is. The cops start giving you and everyone else tickets because "kids today" dont have any sense of restraint when it comes to loud noise. It will eventually lead to laws being passed to prevent us from being able to modify our exhausts at all. The best sounding cars have mufflers. Period.
Here's another, but this one is barely quiet enough to be race track legal, much less street legal, but he built the car to be a track car, not a grocery getter:
https://www.thirdgen.org/forums/exha...gh-rocker.html
Just so you can read through how other people in the world think about straight pipes, and remember the smaller displacement engines dont make nearly as much volume, so just a cat can make up for a lack of muffler. We cant get away with that in our cars:
http://www.r3vlimited.com/board/show...=251842&page=2
http://ls1tech.com/forums/lt1-lt4-mo...r-yay-nay.html
http://mustangboards.com/v6-tech-for...ght-pipes.html
http://www.srt8oc.com/forums/showthread.php?t=25784
Literally EVERYONE hates straight pipes, and they hate them way more than the above car guys do. And real car guys still hate straight pipes.
Old Sep 11, 2012 | 02:23 PM
Engine: sbc 350
ya I changed my mind and I'm gonna run mufflers but which ones will give a deep but some what loud sound I don't want annoying loud tho
Old Sep 11, 2012 | 03:28 PM
Car: 1992 Camaro RS
Muffler will be determined by how much room you have. Personally I think Flowmasters and Aerochambers and magnaflows are all idea mufflers. But you need room to do that, which means mounting it in the back of the car. Running the stock location...
Old Sep 11, 2012 | 03:36 PM
Car: GTA
Originally Posted by InfernalVortex
..... which means mounting it in the back of the car. Running the stock location...
Not true. I have a Magnaflow bullet style muffler under the back seat area with plenty of ground clearance that never bottoms out even over speed bumps & it could be moved forward enough to turn for a side exit.
And I am sure that there are plenty of other makes of mufflers that could be mounted the same way.
Old Sep 11, 2012 | 03:45 PM
Car: 1992 Camaro RS
I wasnt referring to bullet style mufflers. I like full-size mufflers, but yeah if you run bullet style mufflers you should be okay, although they do still take away from ground clearance.
I was referring more to a muffler like this:
http://www.summitracing.com/parts/MPE-11229/
I ran spiralflow bullets for a while and I hated how those took away from my ground clearance too.
Old Sep 12, 2012 | 04:49 PM
Engine: sbc 350
ok found issue turns over and just need radiator now exhaust think ill run those bullet magnaflow mufflers on each side as long as itll sound good ill find out
Old Sep 13, 2012 | 10:30 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I have been wanting to do a side exit exacts like that for awhile. I WILL do it eventually but it's a long way off. There will be a lot of fabrication involved. You would have to section and raise the floor for the exhaust, somehow relocate the LCA mount or have the exhaust swept back at a very extreme angle in order to clear the rear subframe area. If you want it on both sides then you would have to get around the torque arm. Most of the cars that I've seen do this will have the exhaust routed up into the cabin then over the driveshaft like the previously pictured 2nd gen.
Old Sep 13, 2012 | 10:32 PM
DBLTKE's Avatar
Engine: LB9, LB9
Most of the cars/trucks that you see do this are able to get away with it easier because their side skirts hang fairly low to begin with. Ours don't, in fact the floorboards are closer to the ground than our side skirts/GFX are.
Old Sep 14, 2012 | 06:36 PM
Engine: sbc 350
Ya one day I hope I can do the body panel exit but right now I'll have to wait
Old Sep 14, 2012 | 09:40 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
2 of these mufflers:
http://www.summitracing.com/parts/WLK-17676/
mounted under the rear seats, with a turnout in front of each wheel would be pretty badass. with long tube headers and an X pipe i bet it would sound pretty good and move enough air to support something like 500hp.. the only problem then becomes ground clearance where the pipe turns out under the rocker panel, but that could be overcome with some NASCAR "boom tube" style exhaust tips that are only a couple of inches tall and 10" wide..
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
