longtubes for an 88 l98
Old Oct 11, 2012 | 07:24 AM
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
im looking into a set a of longtube headers for a bone stock 1988 formula 350.
im young and on a budget looking for suggestions on what to buy,instalation tips,etc. any help is appreciated.
Posted from Thirdgen.org App for Android
Old Oct 11, 2012 | 07:33 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: longtubes for an 88 l98
Can you build an exhaust system? Do you like having no ground clearance? If yes to both of those, Hedman 68460.
Old Oct 11, 2012 | 08:47 AM
speedlimit96's Avatar
Car: 92 25th anniversary z28!!
Engine: 5.7L 350
Transmission: 700R
Axle/Gears: stock
i have a pair of hooker header super comp long tube that i had installed on my car but i took them off before i sold the car, i drove maybe twenty miles with them on, no problems, the only problem is that b/c the car sat for so long with them on the ceramic coating has been chipping off, you can get them re coated for about 200.00 bucks if you want them pretty looking, i will sell them for 300.00 plus shipping?
Old Oct 11, 2012 | 12:56 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Like he said ^^^
I would never recommend long tubes on a street car, they are worthless unless opened up.
Old Oct 11, 2012 | 01:35 PM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Doug's ceramic coated long tubes find em in jegs ,fit we'll but I had to set motor on top of em cause they don't drop in. I'm using em.
Old Oct 11, 2012 | 04:11 PM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
I agree with dyno don.
On a street car with stock motor youll notice little difference if any with a LT over shorty...which has exhaust options.
Long tubes will make speed bumps etc. Worse for little gain in HP.
Old Oct 11, 2012 | 04:57 PM
Guest
Guest
Posts: n/a
my coated 2055s tapped on -2- speed bumps in the parking lot at work...I was mad..they haven't been on the car a month AND I crawled over the bumps.
- ( I now just drive across the back of the lot to bypass them and other cars.)
Old Oct 12, 2012 | 12:02 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Save your pennies and buy a set of Don's.
Old Oct 12, 2012 | 02:20 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
It depends on the rest of the exhaust. I know two people with thirdgens running 2210's. Neither has ever had issues.
Old Oct 12, 2012 | 10:37 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
I have a set of hookers LT header, And I have ye to drag them on anything, Now my dual cats I do, I would never use shorties or dyno dons over priced over hyped would never flow as well as my hookers,
Old Oct 13, 2012 | 06:50 AM
Ice cold spit's Avatar
Car: 91 Camaro
Engine: 383 carbed/headers/nitrous
Transmission: th400
Axle/Gears: Chevy 12 bolt w/411 gear
I have had both long tubes and short from my experience unless your building a race car there's no need for long tubes, mainly because of one all the custom bending that comes with getting a y pipe to get good ground clearance. a lot of times your old saggy suspension that's stock and old can even screw ya. So from personal experience keep your eyes open on this site for a good deal I've bought some good used parts here. Good luck
Old Oct 13, 2012 | 09:18 AM
Ingram78's Avatar
Car: 1985 firebird
I've used both and I disagree. Long tubes helped my track time and acceleration on the street. Shorties are peeky on dynos and longtubes gave me more smooth power. Granted I have true duals and an Xpipe.
Old Oct 13, 2012 | 01:05 PM
Car: 1992 Camaro RS
All the dyno graphs Ive ever seen corroborate this.
The peak power numbers for LT's are higher, but only by a few horsepower, almost within the margin of error. But the LT's always make more torque in the low end. Theres more power under the curve. After peak torque it evens out between shorties and long tubes, but before peak torque the LT's have an edge.
Now Im definitely not recommending LT's. It takes special circumstances to make them a good idea. Most people dont fit those.
Old Oct 14, 2012 | 05:33 PM
Axle/Gears: 2.77
im stil confused but i can build an exhust and ground clearence is for trucks so i think il be going with the hedmans
Old Oct 14, 2012 | 05:49 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
2055's Y-pipe hangs particularly low compared to the other shorties. Its a documented fact. On my car you can SEE the ypipe hanging.
This is because the 2055's use a ball flange, so the exhaust isn't always as tucked as it should be. Before tightening 2055's ball flanges up you should get the ypipe as close to the floor as possible without it rubbing the floor. It helps, but it still hangs low.
Old Oct 14, 2012 | 10:00 PM
Car: 1992 Camaro RS
Go grab a tape measure and get under your car. measure the distance from the bottom of the transmission crossmember to the ground and see what you get. Most likely you will get between 4 and 6 inches. Now subtract the diameter of the pipe you're using. Thats how much ground clearance you will have.
This is my old dual exhaust setup. I got rid of it because when I put in my T56 I was able to take advantage of the smaller footprint of the T56 trans and use a special crossmember and tuck the pipes up higher.
I would never recommend LT's unless you're 1. A competitive drag racer making 400+hp or 2. You have a T5 or T56. The T5 requires some special considerations (cutting and welding) on the Hedmans to make them work nice together, but it can be done.
You can get 95 percent of the power (power under the curve difference, and Im probably being generous, peak power difference is 1 percent of less) with shorties, AND you can have ground clearance and use a stock exhaust route.
Old Oct 24, 2012 | 04:44 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I have also run both LTs and have switched to Dyno Dons shorties. Regardless of how well the LT headers might work vs the shorties on a dyno, getting any kind of decent sized exhaust pipes around the trans mount/subframe is not gonna happen on a thirdgen without major surgery.
I know I picked up power going from smashed and mutilated 2.25" tubes off my LT collectors to beautiful mandrel bent 2.75" tubes from the Dyno Dons shortie headers. For a race car w/ open headers, the LTs are an option. For a low street car, you're going to pull your hair out trying to get a decent exhaust on them, giving the real power advantage to the shorties because you are not corking them up with smashed headpipes <on a third-gen chassis>.
TA
Old Oct 26, 2012 | 08:39 PM
89L98TPI's Avatar
Car: 89 Corvette
Scrap that Fbomb and get a C4 Vette like your brother
Old Oct 26, 2012 | 09:22 PM
Ingram78's Avatar
Car: 1985 firebird
Notched crossmembers help tremendously here. I run my 3" duals alongside my th350 and they only hang down an inch more than my deep transmission pan.
Old Oct 26, 2012 | 09:27 PM
Ingram78's Avatar
Car: 1985 firebird
Here is a crappy pic of said crossmember..... Fabbing up one from chrome moly tubing right now that's even more simple.
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Tarizza
Sep 24, 2015 12:57 PM
