Edelbrock TES header clearance
Old Oct 13, 2012 | 04:57 PM
Guest
Guest
Posts: n/a
Passenger side was a breeze. A walk in the damn park. The driver's side header is hitting the steering column and these two silver metal pipes down below just next to the oil filter. How do I remove the steering column? I just need the part of the steering column that's up by the head removed, Any advice? And how about those two metal pipes? They are fairly large so I am calling them pipes rather than lines, although i think someone told me they are brake lines. I have an idea how to remove them, but is any fluid going to come gushing out? Thanks a million in advance guys I just dont want to screw up anything more than i already have.
Old Oct 14, 2012 | 07:08 AM
Re: Edelbrock TES header clearance
Easier by far, to remove the engine mount through-bolt on that side, and tilt the engine up with a hoist or the like.
You may still have to bend the brake lines a bit; there's some variation in those from car to car, and the way they go in some cars, puts them right in the way of just about everything. No need AFAIK to remove them for that though.
Old Oct 14, 2012 | 08:29 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
What he said. Pretty much any headers you get for these cars you will need to jack the drivers side of the motor up. I have the TES headers and they actually fit and clear things very well. I dont like their design powerwise but their clearance to other things in the car (framerails,steering column and K member) is excellent.
z 28 jari
Sep 14, 2021 10:03 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
bamaboy0323
Sep 12, 2015 07:14 PM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
