What do u think of this setup??
Old Oct 14, 2012 | 12:28 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I want to put my hooker 2055's on my stock LG4 engine but I have a problem and that's im a tight budget...all I have is $500.......so I was thinking of doing straight pipes and adding my flowmaster 10 with the headers....any idea if that will sound any good, or
plan B...install the headers and just weld on a universal 3" magnaflow cat with the flowmaster 10 series....??
plan c- headers with just the magnaflow 3" cat...no muffler...
Old Oct 14, 2012 | 10:06 PM
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
Re: What do u think of this setup??
I say go with plan B. Since you're in CA, they might not allow you to go the other options with strict emissions.
Old Oct 14, 2012 | 11:24 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
I'm not understanding the problem,
But let me give my opinion(and remember that's all it is)
You already have your headers,
$300-350 will buy you a good cat back(magnaflow, Mac, ect.)
$100 or less will buy you a cat
Bolt it together and go,
Unless I'm not understanding your question
If I were to choose any of your 3 options it would also be plan B
Old Nov 1, 2012 | 09:09 AM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
I currently have Long tube headers straight pipe duels (no cats) w/ 40 series Flowmasters turning down right b4 the rear end.. Its pretty loud but not crazy loud. Get looked @ alot but i like to think its the car.. lol
I hate the ground clearance though.. You know Cali street/hwy's suck a**.. Dips and pot holes everywhere. lol
Good luck..
Old Nov 7, 2012 | 08:07 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
If you don't already have the headers, you're going to have a hard time getting all of that together and installed for under $500. that said, Your plan B is the one you want.
Old Nov 7, 2012 | 10:45 AM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Plan B is probably your best bet. I think you'd be better off and maybe even happier saving up for a full exhaust though. I'm assuming with plan b you're going to have a y pipe? The 10 series with just a turn down or whatever you want to do is going to be LOUD, as you probably already know. In my opinion, because of all of the droning that is going to happen inside your car, it's going to be too loud. You can even find a used cat back on here or another site alike for cheap. I paid under $200 for a full 3 inch exhaust, headers all the way back, in great condition from another member on here. That's just my opinion though, if you can deal with the loud all of the time then do it!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
