custom flowmaster exhuast finally done
Old Oct 16, 2012 | 08:09 AM
86'sportcoupe's Avatar
Car: '86 Sport Coupe
Engine: 310"
Axle/Gears: Stock 10 bolt. 2.73's
heres a sound clip ands pics its headman headers and y pipe a magnaflow high flow cat and a flowmaster 40 series delta flow muffler
the engine is lightly built mild cam, edelbrock intake holley carb ported heads ect...
Old Oct 16, 2012 | 12:36 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: custom flowmaster exhuast finally done
geez i'd back out my driveway and rip that off...
Old Oct 16, 2012 | 01:49 PM
Engine: 310"
the clearance isnt too bad i have about 3.5 in at the lowest point
Old Nov 19, 2012 | 02:28 AM
Bbourk89's Avatar
Car: 1989 camaro RS
Engine: 5.0 TBI
Transmission: 700 r4 auto
okay hi to all i have an 89 camaro 305 tbi and i was wondering if i could use the flowmaster 10 series muffller 1 inlet with dual outlets even though its not a crossflow muffler, i intend on hooking the cat pipe to one of the dual outlets and have a pipe running out of the other outlet and another pipe running out of the inlet like the crossflow setups. will this work Please give FEEDBACK!!
Old Nov 19, 2012 | 02:07 PM
Engine: 310"
it probably would work but it would sound like crap because your putting the inlet in the outlet and it would be stupid loud because its a 10 series
Old Nov 19, 2012 | 04:31 PM
Bbourk89's Avatar
Car: 1989 camaro RS
Engine: 5.0 TBI
well if i put the cat pipe in the single inlet do u think id have enough room to run 2 pipes out of the outlets to out the back of the car to simulate true duals
Old Nov 20, 2012 | 06:17 AM
Engine: 310"
that should work, it would be easiest to run them under the axle but if you want it to look factory you would need to run them over the axle, you might run into some clearance issues
Old Nov 20, 2012 | 01:48 PM
Bbourk89's Avatar
Car: 1989 camaro RS
Engine: 5.0 TBI
in your opinion what would be the best way to set up the muffler with dual pipes from the outlets? also are you talking about ground clearance issues if i run the pipes over the axle?? or are you sayin their may not be enough room to run both pipes over the axle? thank you for the feed back i just want to make sure i do this right
Old Nov 20, 2012 | 01:54 PM
Engine: 310"
because its a 10 series witch is pretty small i would run pipe to the back in the stock location and put the muffler in the back also in the stock location and just run some pipe off of the outlets to the tips, that way you stay in the stock location until behind the muffler
Old Nov 20, 2012 | 02:04 PM
Bbourk89's Avatar
Car: 1989 camaro RS
Engine: 5.0 TBI
I'm trying to understand wat ur sayin I apologize ahead of time but so ur sayin put the muffler sideways under the trunk like stock but run cat pipe to inlet and run pipes out of outlets to the factory dual tips that are in the factory location?
Old Nov 20, 2012 | 02:09 PM
Engine: 310"
Right, factory until the muffler, but it doesnt have to be sideways because a 10 series is so small
Old Nov 20, 2012 | 05:06 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
If I understand what you are trying to do correctly,if you mount the 10 series in stock location, your dual outlet will be facing the drivers side. it would be a pain trying to route a tip to the passengers side location with that little of room for the 180 degree bend it would have to make. There's nothing wrong with exiting the tips on the drivers side of the rear and it would be much easier to do.
Old Nov 20, 2012 | 07:50 PM
Engine: 310"
like i said it wouldnt have to be sideways you could have the muffler face the back of the car so it would be much easier to do the duals out the back but you would have to modify the cat pipe to get the muffler in the right direction
Old Nov 20, 2012 | 08:15 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
.....There's nothing wrong with exiting the tips on the drivers side of the rear and it would be much easier to do.
That is how SLP did the 1992 Firehawk exhaust.
But you know? You REALLY should have started your own thread to ask instead of hijacking somebody else's thread. Since the OP seems to have no problem with it? I'm helping you out with that pic above but......
Old Nov 21, 2012 | 12:28 AM
ChrisC's Avatar
And since you're going for the 'dual' look just for appearance purposes, that bird's exhaust above looks real good. If you have any other questions or issues along the way or want to get some more 'go' to add to the 'show' of your exhaust (questions on headers, y pipes, etc), start a new thread like BlackenedBird suggested and you'll get more responses!
Old Nov 28, 2012 | 08:00 PM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
That video is bound to end up on Tosh.0 !
Lol just kiddin!
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Deemax
Sep 12, 2015 06:53 PM
89fast5oh
Sep 8, 2015 09:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
