Jegs Y Pipe
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Jegs Y Pipe
Jegs now has a dual cat y pipe for 82-92 F body. 2.5 in! http://www.jegs.com/i/JEGS-Performan...15#moreDetails. Definately gettin this asap
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Jegs Y Pipe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Jegs Y Pipe
Originally Posted by anesthes
Well if you are going to get headers, than get a y-pipe that is meant for the headers...
The stock manifold flanges are a lot higher than aftermarket headers, not to mention in different locations, and the last thing you want is to be under the car cutting the flanges off of the Y-Pipe, raising the Y-Pipe in place, then rewelding it all back together. Been there done that, and its a pain in the freaking azz. Even if you go to a muffler shop, expect to give them a couple of hundred dollars to do it for you. Like Joe said, get a Y-Pipe that is meant for it...
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: Jegs Y Pipe
i doubt I'll get the headers but I do need the y pipe, it says it will fit the stock exhaust manifolds, what ya'll think?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Jegs Y Pipe
100_0558.jpg?t=1327176215
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
