Exhaust Cross Over Pipe Removal ?
Old Dec 30, 2012 | 07:56 AM
Shep5B's Avatar
Car: 1985 IROC-Z H.O. 4bbl
Engine: L69 Small-Block, 305
Transmission: Borg-Warner T5
Kinda having a problem trying to get these nuts off of the studs next to both manifolds. the threads are extremely rusted and are making this a pain. i've tryed penetrating oil on it in the last 4 days. I started the car till it reach tempeture to get it hot and even put candlewax on it. but this sht dont budge.. I dont know if ya'll got any ideas. if you do please share, that would be a big help
heres a couple pictures
http://s1175.beta.photobucket.com/us...tml?sort=3&o=0
http://s1175.beta.photobucket.com/us...tml?sort=3&o=1
http://s1175.beta.photobucket.com/us...tml?sort=3&o=2
ps:: I aint tryna cut the exhaust neighter
Old Dec 30, 2012 | 08:01 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Exhaust Cross Over Pipe Removal ?
The trick here is to get the nuts glowing orange hot with a torch, and they will come off easily. Exhaust heat won't do it.
Old Dec 30, 2012 | 08:03 AM
Shep5B's Avatar
would those bernz o matic torches work for this
Old Dec 30, 2012 | 08:08 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Probably not, you need an oxy acetylene torch.
Old Dec 30, 2012 | 08:12 AM
Shep5B's Avatar
dang gz. them oxy acetylene torches cost bread
Old Dec 30, 2012 | 08:56 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
You might be able to do it with the Benz-o-manic if you get a cylinder of mapp gas for it. It will be the yellow cylinder not the blue propane one. The mapp gas burns hotter than propane.
Old Dec 30, 2012 | 11:14 AM
Shep5B's Avatar
damn yall. i got 2 off and 2 snapped on me. what do i do now.. cause you know if i try taking the exhaust manifold off am sure those bolts are gona be a bch 2
Old Jan 1, 2013 | 04:27 PM
Pop the manifolds off and take em to a muffler shop and get em to put new studs in.
Then when you put it back together, use a little copper anti-seize and stainless steel nuts.
Old Jan 1, 2013 | 05:22 PM
Twin_Turbo's Avatar
Taking the manifolds off can be a major paint in the behind, the french locks will all be rusted, the nuts probably ruste to the studs so you will tear up the heat shields with the stuf spinning... major PITA!!
Old Jan 1, 2013 | 05:43 PM
Edwardgp's Avatar
Engine: 454-350
Shep did you get the nuts red hot like was suggested?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
