Look alike Edelbrock TES header system. Good or bad?
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
These Pro Tuning Lab header system doesn't have all the pinching that the Edelbrock TES has at the collectors from the headers and the y-pipe. So do you guys think that they will flow better the the Edelbrocks?
Edelbrock TES = https://www.thirdgen.org/forums/exha...brock-tes.html
Pro Tuning Lab = http://www.protuninglab.com/ts-he-ccam82-50l-c.html
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Look alike Edelbrock TES header system. Good or bad?
I'll vote yes. The collectors actually look a bit less restrictive than Vic's overpriced/under-performing ones.
Car: 1985 Z28 Camaro
Engine: 390CI SBC Stroker
Axle/Gears: 4.10 (Ford 9")
Hell those look nicer then the Edelbrocks! The quality on on the TES headers is absolutely horrible.
They do not look like the edelbrocks in that they don't have that tube running over the other on the pass side, making it difficult to acces stuff down there. They also don;t have the squished tubes into the collector. These look a lot better.
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
I dont like the Ebrocks, the y pipe is on the side of the pinch weld on the body so i cant use my UMI SFC.
Oh yes you can, I installed UMI SFCs on a 92 GTA with Edelcrap TES ehxaust. I did however build a custom y pipe
You should take one for the team and buy a set. they sure sound good - stainless steel with air tubes. I wonder what size primaries they have.
I would take one for the team, if I had the money. If I can sell my EDL TES that I got, and turn around and buy those, them I'm all for it. But due to all the negative info on the edelbrock's, I don't think anyone would buy mine for $200 shipped.
86IROC112
Aug 17, 2015 02:00 PM
