Performance Gains with Dyno Dons Headers.....
Old Mar 9, 2013 | 04:20 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
If you are using his headers, what kind of performance did you see or feel? Just curious!
Old Mar 9, 2013 | 08:05 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
Re: Performance Gains with Dyno Dons Headers.....
Every engine will vary. some motors feel more of a gain then others. Im sure higher breathing engines like a higher flowing fuel injection motor with a sad poor flowing exhaust system would really benifit from the step up. I always say dons are the best shorty headers out there in 3rd gen land.
Old Mar 9, 2013 | 08:26 PM
Car: 91 formula
By the way thanks don.
Attached Thumbnails Performance Gains with Dyno Dons Headers.....-formula-firebird-sub-frame   Performance Gains with Dyno Dons Headers.....-formula-firebird-sub-frame
Old Mar 9, 2013 | 08:28 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Indeed. Don's are the best shorties out there, bar none. Whatever performance gains are to be had, they will be the greatest with these.
Old Mar 9, 2013 | 11:36 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Wow, those are a work of art! What y-pipes are you guys running with them? I'd imagine that makes a substantial difference too. A lot of people rave about the one that comes with the Hooker 2055's but those headers are only available with the stupid AIR fittings... Dyno Don's + an equally good y-pipe sound much better.
Old Mar 10, 2013 | 09:46 AM
VincentZ28's Avatar
He makes a y-pipe for single and dual cats. Also with and without air tubes.
Old Mar 11, 2013 | 09:07 AM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Just ordered a set from him last week cannot wait until I can out them on. will definitly be a treat coming home from deployment and taking my car out of its 5 year hiatus with some Dyno Dons to wake it up Since my car is mainly stock I would not doubt 20hp (at least) over the stock manifolds.
Old Mar 12, 2013 | 02:34 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Well I got a lot people trying to call BS on me last time I mentioned this but I picked up 1.2 seconds and 8mph in the quarter mile. Conditions were damn near identical (ambient temp, barometer reading, windspeed, humidity, track prep).
Old Mar 12, 2013 | 03:39 PM
VincentZ28's Avatar
Do you have a single cat or dual cats? I know for sure if you would have had 3.42gears instead of 3.73's you would have broken into the 13's over 100mph because with those gears, you were max out before you cross the line. The max HP is at 46-4800 and you were there at the 1000ft mark. Trust me I've been there and done that. At 5000rpms you should be at 98-100mph. If you had 3.42 you would be at 110@ 5000rpms not to say you would be going that fast but when you cross the line it would be around 4500rpms and still in the power band at 102-104mph.
Old Mar 12, 2013 | 09:39 PM
DBLTKE's Avatar
Engine: LB9, LB9
I had the N10 cats/y-pipe when it was stock, with the Dyno Dons I'm running catless. I had true 26" tall tires on as opposed to the stock 25.6". Not a huge difference but just enough to put me at or around 4800 at the stripe. Sometimes I wish I still had the 3.42's though.
Old Mar 13, 2013 | 12:06 AM
Car: 91 formula
I can wait to gets these headers in. After all Im replace this. This old dented y-pipe with factory manifold. I ordered the duel y-pipe. it will all be mated to a gmmg catback system.
Attached Thumbnails Performance Gains with Dyno Dons Headers.....-car-repair-91-formula
Old Mar 13, 2013 | 07:54 AM
VincentZ28's Avatar
Well since I have the 245hp L98 with a T5 and 3.42's, I would get to the Finishline before you.
MustangBeater20
Oct 29, 2022 09:20 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
midias
Aug 22, 2015 01:42 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
